Great Router Video from Norm - Router Forums
 12Likes
post #1 of 15 (permalink) Old 12-04-2015, 08:51 AM Thread Starter
Default Great Router Video from Norm
Having taken a break from trying to learn woodworking, I'm hoping to learn some new skills over the holidays, weather permitting. My interest in woodworking was inspired by Norm. This video is one of the best introductions to routers I've seen, so I highly recommend it to other beginners. What frustrates me about it, though, is the dado jig. He cuts the dado, and the shelf fits perfectly. In my limited experience, it's next to impossible to get a bit to fit the thickness of a shelf perfectly. I can only assume that he either milled the shelf to match the bit, or he got lucky. My guess is that for most people using this jig, it would be better to use a 1/2" bit and to cut the dado in two operations, shifting the jig from one side of the 3/4" dado to the other. Your comments and suggestions are welcome.
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #2 of 15 (permalink) Old 12-04-2015, 10:01 AM
Mike, plywood bits are sized to work with the 1/32" reduced sizes. Solid wood is still on 1/4" sizes.
Moz likes this.
post #3 of 15 (permalink) Old 12-04-2015, 10:22 AM
CharleyL's Avatar
First Name: Charley
Mike,
Make yourself one of these jigs and your router dados will be the perfect width every time.
Charley
Exact-Width Dado Jig
kp91, Stick486, Semipro and 1 others like this.
Central North Carolina
CharleyL is online now
post #4 of 15 (permalink) Old 12-04-2015, 11:25 AM
gjackson52's Avatar
First Name: Gary
Also remember that what we saw on the video is not necessarily all that happened. If I remember right, Norm did say that the show was edited for time, and that you didn't always see everything that went into making his projects. Even with that said, I agree...Norm was great to watch.
Gary
gjackson52 is offline
post #5 of 15 (permalink) Old 12-04-2015, 07:36 PM
Originally Posted by CharleyL View Post
Mike,
Charley
excellent...
use a top bearing mortising bit and take the KISS/MISS route..
better quality bits for less money...
Freud Tools | 1/2" (Dia.) Mortising Bit
Stick486 is offline
post #6 of 15 (permalink) Old 12-04-2015, 07:48 PM
TwoSkies57's Avatar
Never assume anything..
nominal Thickness Actual Thickness
1/4” 1/4”
3/8” 11/32”
1/2” 15/32”
5/8” 19/32”
3/4” 23/32”
1-1/8” 1-1/8”
Thickness in Millimeters
Thickness (inch) Thickness (milimeter)
1/8” 3.2mm
1/4” 6.4mm
5/16” 8mm
3/8” 9.5mm
7/16” 11.1mm
1/2” 12.7mm
5/8” 15.9mm
3/4” 19mm
1-1/8” 28.6mm
1-1/4” 31.75mm
Baltic Birch produced to metric equivalents.
Source: Plywood Thickness | ThePlywood.com
comment from Norm A. himself on plywood:
Norm Abram replies: I come up against this problem all the time, and there's no simple answer. For starters, plywood is not like lumber; it's made to the thickness actually stamped on its face. The problem is, the manufacturing tolerances vary depending on the kind of plywood being made. For instance, sanded grades of softwood plywood that are ¾ inch thick or less — the type you'd probably use for utility shelves — are manufactured to tolerances of plus/minus 0.4 mm (1/64 inch). Most other softwood plywood, including the unsanded grades, is manufactured to a tolerance of plus/minus 0.8 mm (1/32 inch).
Hardwood plywood, which is used to build higher-quality cabinets and shelves, is a slightly different story. Panels ¼ inch thick or more are made to a tolerance of plus 0.0 mm/minus 1.2 mm (3/64 inch). A plus-zero tolerance is dictated by the cabinet and furniture manufacturers, the biggest users of this material, who can live with a panel that's slightly too thin but not one that's too thick, because of the assembly problems it causes.
http://www.thisoldhouse.com/toh/askt...459293,00.html
ksidwy and PhilBa like this.
Skipper the Penguin
TwoSkies57 is offline
post #7 of 15 (permalink) Old 12-05-2015, 08:49 AM
PhilBa's Avatar
First Name: phil
I'll toss in that dimensional lumber often isn't of a consistent thickness, either. I've gotten boards that are sold as 3/4" thick but are often 1/64" to 1/32" less. Your best bet is an exact width dado jig so you make a dado based on the actual thickness of the board you are going to use. This is sometimes hard when you are making a dado for the bottom of a drawer or such but for shelves and carcases it makes a lot of sense. You certainly can tune a dado blade to the correct thickness but for the router approach you are stuck with the existing bit widths.
By the way, router bits aren't all that consistent either. When you combine bit runout and collet runout you can get a wider slot. Usually not terrible but it can lead to a looser fit than you would think. It happened to me with a freud bit and PC collet (not talking about low end stuff here). I got loose box joints. A quarter turn of the bit in the collet and I got tight ones. The difference was a little less than 1/64".
Visit my shop website.
PhilBa is offline
post #8 of 15 (permalink) Old 12-05-2015, 08:59 AM Thread Starter
And there you go. I get my confidence up, and then I realize that I'm probably just getting ready to make another mess.
patlaw is offline
post #9 of 15 (permalink) Old 12-05-2015, 01:10 PM
kp91's Avatar
First Name: Doug
Exact width jig using template guides. Works like a charm
jw2170, Nickp and ksidwy like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #10 of 15 (permalink) Old 01-03-2016, 10:58 AM
First Name: Ken
Hi there. I have only just taken up the hobby and have just bought a router and table.
The first project that was undertaken was a dado jig that didn't need a bush. The only real stipulation is that you use the same bit with the jig every time.
I used wing nuts instead of the ones that need a spanner to make it easier.
I hope I have been able to help as this is my first post apart from my introduction.
Oh dear I have just realised that I cannot use URL's yet but the guide I followed can be found by googling ukworkshop videos Adjustable dado / housing joint jig.
Hope I havn't broken any rules by doing that.
Ken
taralabradog is offline
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
A great inlay video Bob N Guide Bushings and Templates 2 12-24-2009 01:50 PM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
