Back Scratcher - Router Forums
 7Likes
post #1 of 12 (permalink) Old 12-04-2015, 11:01 AM Thread Starter
First Name: Ron
Default Back Scratcher
I know this sounds silly but my wife would like a back scratcher made. Anyone know of sample plans for this important item? Any do's or dont's when making one? I would think that the orientation of the grain and type of wood might be important. Any thoughts would be appreciated.
rweerstra is offline
post #2 of 12 (permalink) Old 12-04-2015, 12:43 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Bamboo makes a great back-scratcher. Find a piece of bamboo that is alive, cut it off where it's about the diameter of a broom handle. Keep two entire segments with one having a "fork" of two small branches. Break-off each of said small branches at their first knuckles (about 2" from handle shaft). Let it dry.
This will serve you well for many years. Everyone in my family has several of these around their houses. Guests at our homes always want them too!
ksidwy likes this.
OPG3
Tweak everything!
OPG3 is offline
post #3 of 12 (permalink) Old 12-04-2015, 12:43 PM
Ron here is one I made many years ago, and still use it.
The dimensions are: OAL 19"
Handle: 1'X1'X3 1/2"long
stem: 5/16" X 1/2" X aprox. 12" long
top: 1" X 1/4" X 3 1/2" long
It takes about 10 min. to make . I cut it out of cherry on the band saw.
Name:	IMG_2191 (800x600).jpg
Name:	IMG_2192 (800x600).jpg
Name:	IMG_2193 (800x600).jpg
Name:	IMG_2194 (800x600).jpg
bigmuddyriver, ksidwy and Murtu01 like this.
Herb Stoops is offline
post #4 of 12 (permalink) Old 12-04-2015, 12:51 PM
Good idea Otis, bamboo is not prevalent here,not to say it doesn't grow here, but only available if you find someone with some for landscaping. The things that can be built from bamboo are endless, great material.
ksidwy likes this.
post #5 of 12 (permalink) Old 12-04-2015, 04:03 PM Thread Starter
First Name: Ron
Thanks guys. That was helpful. I may doll it up a bit on the lathe. I don't know if I can get any bamboo around here but I will look.
post #6 of 12 (permalink) Old 12-04-2015, 06:43 PM
get a cat...
post #7 of 12 (permalink) Old 12-04-2015, 10:29 PM Thread Starter
First Name: Ron
I thought of a cat but they hang around for up to 12 years and you have to feed them.
post #8 of 12 (permalink) Old 12-05-2015, 05:37 AM
then make it a dog...
total massages too...
bit of training curve..
post #9 of 12 (permalink) Old 12-05-2015, 07:58 AM
First Name: Dick
I made a whole bunch that were extremely simple but very satisfying to the recipient. All from dowel stock. Dimensions to suit. Here is what I used.
Head: 5/8", ca. 3" long
Teeth and shaft: 3/8", shaft length - whatever feels right
Handle: 1". ca. 3" long
Drill 4 equally-spaced holes in a line in the 5/8" head for the teeth. Glue in 3/8" dowels to protrude ca. 3/4" (or more if you want longer teeth.)
Drill another hole centered between tooth 2 and 3 in the head at about 45° to the tooth axis for the 3/8" shaft. Glue.
Drill the end of the handle to take the other end of the shaft. Glue.
Drill a last hole in the handle, if desired, for a leather hanging strap (shoelace?)
After it is all together, hold the contraption vertically at the desired angle and saw the teeth at an angle on the table saw. The sharp part is on the same side as the shaft. I try to get the blade as close to the head as I can to keep the teeth short, but that's just me.
It is important to cut the teeth carefully with a fine blade to avoid splintering. By the way, the sharper the angle of the teeth, the better it feels, so don't go crazy with the sanding. It can always be toned down if the user finds it too aggressive.
Finish however you wish. I messed around with different stains for the different parts, but that is fussy. Salad bowl oil makes a nice finish, but it is just as useful with no finish at all.
ksidwy likes this.
rlauterbach is offline
post #10 of 12 (permalink) Old 12-05-2015, 11:45 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Get a young child, and teach them a game called "guess what I'm scratching your back with" - works up to about age 9!
ksidwy likes this.
Wildwood is offline
I'm back Mike Lobby 13 04-09-2011 08:52 PM
MIA Bob is back Bob N Lobby 4 08-25-2008 11:10 PM
We're back! Mark Lobby 4 02-06-2005 06:18 AM
Back of router table Dr.Zook General Routing 11 09-27-2004 11:18 AM
