Dovetail Bit Question - Router Forums
 2Likes
  • 2 Post By DonkeyHody
post #1 of 6 (permalink) Old 12-07-2015, 01:27 PM Thread Starter
Ken Bee's Avatar
First Name: Ken
Default Dovetail Bit Question
I have a PC 2016 Dovetail Jig and it calls for 7 degree dovetail bit usage. My question is, what is the difference in the various other bits that are of a different degree? It seems to me the only difference is the Dovetail appearance in the finished project. Not that I plan to use a different degree bit in my jig but when shopping for a new bit I saw all the different bits and the question popped into my mind so could somebody please enlighten me. Thanks.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #2 of 6 (permalink) Old 12-07-2015, 02:20 PM
Ken the angle on the jig is set up for a certain degree bit. Different jigs ,different degree bits, free hand and homemade jigs use what ever you want.
Herb Stoops is offline
post #3 of 6 (permalink) Old 12-07-2015, 03:43 PM
DonkeyHody's Avatar
First Name: Andy
Ken, I believe you'll be OK using a different angle bit as long as you are making half-blind single pass dovetails, which use only the rounded side of the jig. In that case, your pins and tails are made using the same bit.
If you are making through dovetails using a straight bit on the side of the jig with pointed tapered fingers, then those fingers are tapered at 7 degrees to match the 7 degree taper of the dovetail bit.
Nickp and Herb Stoops like this.
ďWe should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore.Ē - Mark Twain
DonkeyHody is offline
post #4 of 6 (permalink) Old 12-07-2015, 06:25 PM
First Name: Earl
Right answers about the combination of bits. There may be a few other angles in the Supplemental Manual for that jig--look here http://www.routerforums.com/porter-c...etail-jig.html I don't recall for certain, which is life these days!!
earl
greenacres2 is offline
post #5 of 6 (permalink) Old 12-07-2015, 10:23 PM
furboo's Avatar
First Name: Rob
I believe some increase the angle (say to 14 deg) for softer woods to increase the strength of the joint.
furboo is offline
post #6 of 6 (permalink) Old 12-08-2015, 10:55 AM Thread Starter
Ken Bee's Avatar
First Name: Ken
Thanks for the info guys. Even though I have the PC jig I am going to try my hand at free hand dovetails in the near future.
Ken Bee is offline
Craftsman Dovetail Fixture 720-2570 vuldub Jigs and Fixtures 3 11-26-2017 04:32 PM
Mortising Stair Stringers - Dovetail bit Stormin Norman Jigs and Fixtures 12 01-06-2017 12:48 AM
straight bit rabbeting question from a nubee. xoxo-aj Router Bits - Types and Usage 13 12-30-2011 04:06 AM
