Is this router lift a good deal? - Router Forums
 4Likes
post #1 of 14 (permalink) Old 12-08-2015, 03:04 PM Thread Starter
BarnOwl's Avatar
Red face Is this router lift a good deal?
Incra router lift - $175
Woodpecker micro adjustable router lift.
If you do any router work at all, this is a must have. A lift like this makes changing bits and adjusting your router quick and simple. Once you use one, you'll never do it any other way.
It includes 3 lift rings and the necessary wrenches and crank handle for normal operation. It allows for all router adjustments and bit changes to be accomplished from above the table. It works perfectly, but is a few years old. New models retail for $350 +tax.
Cash only - as is.
BarnOwl is offline
post #2 of 14 (permalink) Old 12-08-2015, 03:19 PM
What size router does it fit? Shipping from what zip code?
Herb Stoops is offline
post #3 of 14 (permalink) Old 12-08-2015, 04:19 PM
First Name: Jerry
Sounds very reasonable to me, the freight might be a bit stiff if, as Herb asked, how far will it have to be shipped, but I suspect that the deal will still be a good one. You do need to be sure that it accommodate your router of course. One does need to commit grand larceny in order to get a good deal. The lift should work as well now as it did when it was new and at that time is was well worth the retail price.
Jerry
Roy Drake and Herb Stoops like this.
Jerry Bowen is offline
post #4 of 14 (permalink) Old 12-08-2015, 06:07 PM Thread Starter
BarnOwl's Avatar
Its a craigslist deal, so no shipping. I have a porter cable 690LR and a Bosch MRP23EVS router. I emailed the guy and am waiting for a response.
BarnOwl is offline
post #5 of 14 (permalink) Old 12-08-2015, 06:10 PM
TwoSkies57's Avatar
The rings are generally router model specific.... make sure the lift will work with either of your routers...
Herb Stoops likes this.
Skipper the Penguin
TwoSkies57 is offline
post #6 of 14 (permalink) Old 12-08-2015, 10:19 PM
First Name: Danny
If it fits your router grab it.
I have that same lift and have been using it for several years with no issues.
Making High Quality Kindling
jd99 is offline
post #7 of 14 (permalink) Old 12-08-2015, 11:16 PM Thread Starter
BarnOwl's Avatar
Thanks for your input everyone!!
BarnOwl is offline
post #8 of 14 (permalink) Old 12-08-2015, 11:56 PM
A few years ago when I thought about getting one it seemed most that I looked at were made to fit the PC7518 or 7519 but had adapters available for other makes and the adapters weren't that expensive.
post #9 of 14 (permalink) Old 12-09-2015, 10:55 AM
PhilBa's Avatar
First Name: phil
A couple of thoughts:
- used is always worth a shot. You need to inspect it closely though.
- that lift doesn't have a lock. many WWers don't worry about that but it's a non-starter for me. I want to KNOW the bit won't change height on me. Spirals especially create a lot of pull (or push).
- if the lift is out of production check on the availability of adapters for different routers
Visit my shop website.
PhilBa is offline
post #10 of 14 (permalink) Old 12-09-2015, 11:53 AM
I am always cautious about used gear. See if you can find some data on this. What makes me a little hinky about this lift is that it doesn't have a lock. I have a Rockler lift with a friction stop that ALWAYS crept on me. It is in a junk pile because I won't unload it on anyone else. So research a bit more. Someone must have a pdf of the manual, which will be your starting point. It will tell you whether it will fit or if you are going to need adapters. I'd contact the company and see whether they have the parts. If not, and you can't find out for certain whether it fits as is, then you may wind up with the thing in the junk heap.
RainMan 2.0 likes this.
Can You Use Sear Router As Router Lift? taipan1013 New Member Introductions 7 08-17-2015 11:08 PM
Jessem Router Package with 3hp -- Good Deal? Psychbiker General Routing 2 08-04-2013 11:52 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
