Beading Bits - Router Forums
 14Likes
  • 1 Post By Cherryville Chuck
  • 5 Post By TwoSkies57
  • 7 Post By TwoSkies57
  • 1 Post By mgmine
post #1 of 10 (permalink) Old 12-23-2015, 11:56 AM Thread Starter
berry's Avatar
First Name: Berry
Default Beading Bits
Whenever I see projects with beading details I think they really add a nice detail. I intend to purchase one or two next month and wondered what size bit is most common for furniture items.
And if anyone has any special advice on their use or routing them feel free to give me a heads-up. Or if you can direct me to a thread where this subject has be covered, that's cool.
Thanks for reading and Merry Christmas.
May the grain be ever in your favor.
berry is offline
post #2 of 10 (permalink) Old 12-23-2015, 01:54 PM
Semipro's Avatar
First Name: John_*
check this video
Semipro is online now
post #3 of 10 (permalink) Old 12-23-2015, 05:08 PM
There are a few choices Berry. Sometimes something simple is nice. A little rounding over is okay at times and I've used stopped coves on edges and like the look of that at times. A roundover bit with a smaller bearing so that fillets are left at top and bottom are quite common. If you want more ornate then a roman ogee is the ticket. Fortunately all those bits are relatively cheap because they are relatively small and very common. Size depends on the thickness of board you apply them to.
berry likes this.
post #4 of 10 (permalink) Old 12-23-2015, 05:47 PM
TwoSkies57's Avatar
Hey Berry... I like smallish, understated beading....especially on furniture. Routing a bead is relatively straight forward. Small beads a single pass will do, bigger and then you might want to take 2 or 3ish..
below pics are of a 1/4" bead
Name:	Mia's nitestand A.jpg
Skipper the Penguin
TwoSkies57 is offline
post #5 of 10 (permalink) Old 12-23-2015, 06:49 PM
Nice work Bill.
post #6 of 10 (permalink) Old 12-23-2015, 06:55 PM
TwoSkies57's Avatar
Nice work Bill.
thank you Charles... thats a matching nitestand to go with my granddaughters dresser I made a few months back....
the 2nd pic gives another look at the beading
Skipper the Penguin
post #7 of 10 (permalink) Old 12-24-2015, 08:03 AM
First Name: Art
I got my beading bits at MLCS. What I do when I want to join two pieces together that have a 90 degree angle is to run a bead on a separate piece of wood then cut off the strips a and put a 45 degree angle on them. I then reattach the strips to the piece I'm building. Trying to butt two beaded pieces together will give you a bad looking joint.
berry likes this.
mgmine is offline
post #8 of 10 (permalink) Old 12-24-2015, 08:47 AM
the solution to that is to use a jack miter...
post #9 of 10 (permalink) Old 12-24-2015, 09:06 AM
see if this is of any help...
post #10 of 10 (permalink) Old 12-24-2015, 09:55 AM Thread Starter
berry's Avatar
First Name: Berry
Great info, thanks so much. I'd never even heard of a 'jack' miter before, over the years I must have spent too much time on my day job. Thanks to every one.
berry is offline
Need advice on aquiring bits Goldstar225 Router Bits - Types and Usage 8 03-15-2015 03:28 PM
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
Metric and Imperial Routing Bits awhitecat General Routing 17 11-28-2014 06:10 PM
Need advice CNC End mills Vs. router bits SubmarineGuy CNC Routing 8 11-17-2014 07:59 AM
