Freud FT 2000 problem - Router Forums
post #1 of 4 (permalink) Old 12-24-2015, 12:58 PM Thread Starter
Default Freud FT 2000 problem
I lost the 1/2 inch collet and collet nut to my Freud ft2000 plunge router. I bought replacements through Bosch. The nut threads onto the bore fine, but, when I insert a 1/2 in bit into the collet, the nut can't quite reach the threads of the bore. Any suggestions?
Chris W
oceangrove90 is offline
post #2 of 4 (permalink) Old 12-24-2015, 01:24 PM
Welcome to the forum N/a. I had one of those and it seems to me that the collet "snapped" into the nut. If you take both off, stick the collet into the nut and see if it sits flush against the end of the nut (the outer opening that is). If it doesn't then that is probably what's wrong.
post #3 of 4 (permalink) Old 12-24-2015, 01:37 PM Thread Starter
Thanks, I'll check it out. Seems strange that the new ones would give such a problem.
post #4 of 4 (permalink) Old 12-24-2015, 02:46 PM
You can also try sticking the collet by itself into the shaft recess. I should sit just above flush or flush. If it sticks out farther than that then it is probably the wrong one.
collet problem in Freud FT 2000E dustyiniowa General Routing 4 01-22-2012 09:23 PM
Freud Model FT 2000 E Router gaxtm General Routing 4 10-27-2009 08:18 AM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
