1/4 Collet Adapter Stuck - Router Forums
post #1 of 6 (permalink) Old 12-31-2015, 02:43 PM Thread Starter
Default 1/4 Collet Adapter Stuck
Hi there,
I bought a new Ridgid Router (R2901) with a 1/4 collet adapter and may have tried to put it together wrong. I put the adapter into the router and then screwed the collet nut overtop. The 1/4 adapter is now stuck inside it and I can't get it out. While I was originally screwing it in, the adapter closed up a bit and now the bit won't even fit into it.
I've tried pulling it out many ways and it won't budge. Has this happened to anyone?
Any advice is greatly appreciated!
Cody
codycoyote is offline
post #2 of 6 (permalink) Old 12-31-2015, 03:21 PM
You NEVER screw the collet nut down without a bit in it. Take the nut off and tap all around the collet from the sides with a light hammer and a pin punch and it should eventually let go. Once it lets go you may be able to spread the slots open with a thin bladed screwdriver. That really isn't the ideal way to do it but it probably is the only option available to you. A slide hammer with a round headed screw hooked onto the bottom edge of the collet would be better.
post #3 of 6 (permalink) Old 12-31-2015, 03:25 PM
here's the PDF's...
post #4 of 6 (permalink) Old 12-31-2015, 06:14 PM
Nickp's Avatar
First Name: Nick
Put the collet over a vise opened just enough to hold it above the jaws...take a straight punch that will fit into the collet and touching the 1/4" adapter and tap lightly to push the adapter out the bottom...
Then throw the adapter out, closely examine the inside of the collet and if scored, throw it out also...
That component holds very sharp 25,000RPM whir lie things and you don't want to take a chance...
Nick
Nickp is offline
post #5 of 6 (permalink) Old 01-01-2016, 05:38 AM
jj777746's Avatar
Originally Posted by codycoyote View Post
Hi there,
Cody
Hi Cody,you will get the right advice from the Members here.Happy New Year & welcome to Router Forums.james jj777746
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #6 of 6 (permalink) Old 01-01-2016, 11:28 AM
RainMan 2.0's Avatar
Welcome to the forum Cody
Ok ,I never insulate
RainMan 2.0 is online now
Collet adapter: 1/4" to 1/2" curtcich Router Bits - Types and Usage 5 04-01-2015 11:06 PM
Craftsman 315.25031 collet 1/4 to 1/2 stephen65 New Member Introductions 8 03-24-2015 02:12 PM
Collet adapter to fit a 1/2 to a 1/4 ? chipper5 New Member Introductions 10 11-03-2014 07:35 PM
Collet adapter not available on 3 yr old router Johnniejay General Routing 2 03-30-2012 02:36 PM
1/2 inch and 1/4 inch collet? JohnsoGreg2012 General Routing 6 01-22-2012 12:45 AM
