Locking lever mod for Craftsman 315.296210 - Router Forums
 5Likes
  • 5 Post By ArTrvlr
post #1 of 8 (permalink) Old 01-04-2016, 11:30 PM Thread Starter
Lightbulb Locking lever mod for Craftsman 315.296210
I have had this router for a few years, and it has always been a PITA to use because the lever that clamps the height adjustment in place pops open during use. I have tried several times to tighten, then loosen the adjustment nut on the lever, to no avail. I had pretty much developed the habit of holding the end of the lever with my fingertips while routing. But today, I just got tired of that, and decided to either fix it or make it worse. If I couldn't fix it, I was prepared to buy a new one.
I had never before really examined the lever with the idea of trying to find the flaw in the design, but the flaw was easy to see. The portion of the lever that presses on the flat washer, that in turn presses on the housing, to pull it tight around the motor, was too thick to allow the lever to go over center, which would hold it in place.
A slight adjustment with a file and the lever now snaps into place and stays there.
This is the router:
And the latch on the back side:
I didn't take a pic of the lever before I filed it, but you can see from the depth of the notch how much metal I removed:
And assembled back together:
I have no idea how popular this router is, so I may not help many people with this info. But this may apply to other brands as well.
So, I repaired my way out of getting a new router.
ArTrvlr is offline
post #2 of 8 (permalink) Old 01-05-2016, 12:01 AM
nice solution...
post #3 of 8 (permalink) Old 01-05-2016, 07:58 AM
BrianS's Avatar
First Name: Brian
Nice catch John.
Brian
(Origin uncertain)
BrianS is offline
post #4 of 8 (permalink) Old 01-05-2016, 08:41 AM
TenGees's Avatar
First Name: Paul
Nice modification, John. Reminds me of how I fixed some cheap vice-grip style C-clamps, many years ago. They had a similar problem - didn't lock reliably. I had to grind a little off the 'hump' on the release lever. Then they worked fine.
TenGees is offline
post #5 of 8 (permalink) Old 01-05-2016, 08:57 AM
Even though you fixed it you still don't need a new router? You are not allowed to talk to my wife. Seriously, good job. You looked at the problem, figured out what was wrong, and fixed it. Ryobi, the company that made your router, should have been able to figure that out before you had to though.
post #6 of 8 (permalink) Old 01-05-2016, 09:16 AM
First Name: Roy
If it works, it's good. Way to go.
Roy Drake is offline
post #7 of 8 (permalink) Old 01-05-2016, 10:37 AM Thread Starter
I thought since I only admitted it here, the secret would be safe. BTW, I did recently get a new router, a Dewalt 611 fixed/plunge kit. But that was because I wanted a smaller one, not to replace the Craftsman.
After I posted, just out of curiosity if the lever was still available, I checked the Sears parts site. The lever is available, but the original # has been substituted, so maybe they changed the design.
ArTrvlr is offline
post #8 of 8 (permalink) Old 01-05-2016, 11:25 AM
MEBCWD's Avatar
John,
Never make a modification to your router without having a backup! Buy the backup router then do the modification that way you have 2 routers that work.
MEBCWD is offline
Looking for Craftsman router locking lever spring jimmunnkey General Routing 5 09-16-2013 11:34 PM
Craftsman #315.17480 dew777 General Routing 9 01-07-2013 08:15 AM
Missing locking key on router Rowantree General Routing 2 07-11-2009 04:14 AM
