Good idea or no - Router Forums
 4Likes
post #1 of 19 (permalink) Old 01-07-2016, 01:44 PM Thread Starter
First Name: Dustin
Default Good idea or no
I ordered a dewalt 618 router kit that comes with the fixed, plunge and d-handle fixed bases from lowes. After perusing here, I'm thinking I should cancel the order and get a Bosch 1617evspk.
Main use is in a router table but I want plunge capability also. I need the capability of a 1/2" collet. My current Bosch router is pretty old and only has a 1/4" collet.
Thoughts?
Sent from my iPhone using Tapatalk
hunterguy86 is offline
post #2 of 19 (permalink) Old 01-07-2016, 01:57 PM
Ratbob's Avatar
First Name: Jeff
Seems like there have been a few issues lately with the 618s when table mounted. You'll find lots of Bosch love here on this forum, but if you haven't considered Triton yet have a look at the TRA001. It has a great set of features for table mounted applications, and with 3 1/4 HP it's a beast!
Murtu01 likes this.
Ratbob is offline
post #3 of 19 (permalink) Old 01-07-2016, 02:41 PM
Nickp's Avatar
First Name: Nick
Can't go wrong with the Bosch...easily slips out of the fixed base in the table and into the plunge base for freehand.
If you consider the Triton, know that you will need to take out/reinstall the spring and dismount it from the table when switching from table to freehand and reverse...but it is a phenomenal table router...
Send the Dewalt back, get the Bosch 1617EVSPK (PK designates the fixed/plunge package). Get the dust collection accessory for freehand and the VAC005 hose for table and freehand (unless you have something already)...
I'm sure you'll hear similar from others...
Murtu01 likes this.
Nick
Nickp is offline
post #4 of 19 (permalink) Old 01-07-2016, 02:51 PM
Ratbob's Avatar
First Name: Jeff
All good points Nick, except that the Triton works fine out of the table in 'fixed base' operation without installing the spring. Mine sets up and adjusts easily with the table plate still attached. It just takes seconds to install the spring if you need to plunge.
Ratbob is offline
post #5 of 19 (permalink) Old 01-07-2016, 04:23 PM
Love my Triton 001 - - - my permanent table router.
HJ
Murtu01 likes this.
honesttjohn is offline
post #6 of 19 (permalink) Old 01-07-2016, 05:22 PM
Seems like its a question of whether you intend to use the router only in the table. I consider the Triton TRA001 to be about perfect for table use, but too hefty for me to handle as a hand held.
If you have to use one router for table and free hand use, my choice would be the 1617 EVSPK. The DeWalt is OK, but having looked both over very carefully, the Bosch seemed to have a more solid build.
I used the Bosch in my table for several years and it handled the work just fine, but then, I wasn't using large door making bits at that time. Whether you get the DeWalt or Bosch, when using larger bits you'll want to keep your cuts down to an 8th of an inch per pass. With the Triton, I don't worry much about that.
Cancellation option is nice, isn't it?
post #7 of 19 (permalink) Old 01-07-2016, 05:30 PM
Thoughts?
inna heart beat...
post #8 of 19 (permalink) Old 01-07-2016, 05:33 PM
or get this and have it all...
RA1054 Deluxe Router Guide | Bosch Power Tools
post #9 of 19 (permalink) Old 01-07-2016, 05:37 PM
wasn't there a thread on defeating the lock out feature on the Triton to simplify table mounted bit changing...
post #10 of 19 (permalink) Old 01-07-2016, 06:05 PM
Ratbob's Avatar
First Name: Jeff
There is Stick, but I wasn't addressing what I consider to be a great safety feature, and a very minor inconvenience. It doesn't take much effort to toggle the switch when doing a bit change, and I hate the ER. Too many sick people!
Ratbob is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
Re-calming wood for turnings good idea? Stan Richardson Woodturning and Lathes 10 08-11-2013 11:19 AM
Help with my Bed Idea FordTrax General Routing 12 11-27-2012 06:46 PM
Making puzzles, looking for a jig idea kweinert Jigs and Fixtures 3 08-31-2009 07:59 AM
