moving circular saw blades safely--for the blades-- not me - Router Forums
 6Likes
post #1 of 15 (permalink) Old 01-25-2016, 10:36 AM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Default moving circular saw blades safely--for the blades-- not me
Looking for suggestions for moving my 10 in. circular saw blades, about 18, to a new house.
My current thought is to use a sheet rock joint compound bucket.
Stacking them with cardboard spaces. Put the lid back on and go.
Open for any suggestions.
Thanks in advance
smitty
smitty10101 is offline
post #2 of 15 (permalink) Old 01-25-2016, 10:38 AM
MikeMa's Avatar
I think that method would be fine.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 15 (permalink) Old 01-25-2016, 11:02 AM
Nickp's Avatar
First Name: Nick
No doubt, that will work...depending on how many you have you could also stack them flat in any square box or container that might be a better fit.
You should make sure they are secured so that the teeth don't get banged on the sides (from side to side movement or banging into other items during the move)...maybe the bucket won't have room for that...?
...and fill in between the last blade and the lid so they don't bounce around...
You might also put a dowel through all the centers so they don't slide...
Basically, do anything you can to make sure they don't slosh around...
Nick
Nickp is offline
post #4 of 15 (permalink) Old 01-25-2016, 11:08 AM
Thanks in advance
smitty
bolt the stack together w/ 5/8'' bolt to the teeth don't rattle together chipping one another...
post #5 of 15 (permalink) Old 01-25-2016, 03:20 PM
I do mine like Stick suggests,w/a piece of all thread and a washer and nut on top and bottom.Also use heavy cardboard box material between the blades. If you can cut a piece of plywood for bottom support.
UlrichJ likes this.
Herb Stoops is online now
post #6 of 15 (permalink) Old 01-25-2016, 06:59 PM
adding a layer of craft paper between blades or thin cardboard is a plus too....
UlrichJ likes this.
post #7 of 15 (permalink) Old 01-25-2016, 07:03 PM
make you one or more of these...
post #8 of 15 (permalink) Old 01-25-2016, 08:38 PM
Those are good for storing and moving the blades in the vertical position. Still a good idea to allow room for some kind of padding between blades to keep the carbides from touching. Those could be made to hold 5-6 blades and if you made 3 or 4 of them they wouldn't be so heavy to manage and you could sort your blades by category too.
post #9 of 15 (permalink) Old 01-26-2016, 07:03 AM
katabrontes's Avatar
Bubble wrap?
katabrontes is offline
post #10 of 15 (permalink) Old 01-26-2016, 09:53 AM
Garyk's Avatar
First Name: Gary
The rubbery shelf lining is inexpensive from the Dollar stores. Lots of good methods already mentioned. Bubble wrap might pop if they are bolted together when you tighten down on the nut.
Garyk is offline
What saw blades do you like? Mike Tools and Woodworking 40 10-15-2015 10:06 PM
Freud saw blades... Stick486 Tools and Woodworking 22 08-28-2015 06:34 PM
Jerry Wants To Talk About BS Blades Again Jerry Bowen Tools and Woodworking 24 08-14-2014 08:51 AM
sharpening bits and circular blades SE18 Tools and Woodworking 0 10-13-2009 07:27 AM
