Table with inlaid stones in the top. - Router Forums
 18Likes
post #1 of 21 (permalink) Old 01-30-2016, 01:35 PM Thread Starter
First Name: Scott.
Default Table with inlaid stones in the top.
I'm wanting to make a wooden table with stones inset into its top.
I've seen an example of one that someone else made on the net and copied the pictures onto my computer for reference.
Here is the pictures of the one I like. Again, I didn't make it. Only copied the images off the internet.
Then I've been for a walk along the beach with my three year old ("Nearly four Pops!!!") granddaughter picking up unusual stones and taking masses of pictures all the time.
In the semi distant future would like to set several of these stones in the table top to give her the table, along with the photos of the day finding them.
Now I could cut them out with a jigsaw but am wondering if there's a neater way to do it with a router.
Does anyone have any ideas of a better way?
Rogerdodge likes this.
demographic is offline
post #2 of 21 (permalink) Old 01-30-2016, 02:10 PM
A full size pattern and template would be my first choice.
Another concept you might consider is to slice the rocks in half lengthwise on a wet saw (rocks mounted cut side down). It'll make the routing part simpler, and certainly more comfortable to sit on if the rocks don't stick up too high(?).
https://www.homedepot.ca/en/home/p.7...FZBhfgodLF8H8Q
DaninVan is online now
post #3 of 21 (permalink) Old 01-30-2016, 02:23 PM
trace the stone and cut a template...
mark the location for the stone using the template...
make the cutout w/ your jigsaw or router...
use your router w/ a RO bit to soften the edges...
plan ''B''...
do the stone as an inlay...
Making Inlays With A Router - NewWoodworker.com LLC
perfect the fit on scrap 1st...
demographic and Shop guy like this.
post #4 of 21 (permalink) Old 01-30-2016, 09:41 PM
First Name: Richard
+1 what Dan and Stick said.
Shop guy is offline
post #5 of 21 (permalink) Old 01-31-2016, 08:11 AM
DonkeyHody's Avatar
First Name: Andy
A sharp chisel?
DonkeyHody is offline
post #6 of 21 (permalink) Old 01-31-2016, 09:08 AM
johnnie_dr's Avatar
Hi Demo,
I did a similar table last year. Hadda old piece of Chestnut burl that I wanted to inlay (table top is maple and cherry). I sliced the burl, traced the pattern on top, then routed it (very carefully)...as Dan & Stick mentioned, then used 2 part epoxy, filled in the gaps. Flattened it all down (as the burl was rather proud to table top...as I intended) with a power-planer, then subsequent grades of sandpaper...etc.
Once I conquered that, I got some polished river stone and did the same thing. I laid out the stones where i wanted them, traced the outline, then using a trim-router and a 1/2" core box bit, roughed out the hole (with rounded bottom & sides) to allow me to fit the stones into the top...again, about 1/2 depth of the stone proud. Used the epoxy again, although this time, carefully added it around the edge of the stone to just bring it level to the surface of table, since I could not sand or file the cured epoxy around the stone. All of this had to be done AFTER having done surface prep to the table top (sand, prep, & at least 1 coat of poly), since you don't want to poly over the stones.
Fun project...some people look at the table and say "gee...WHY did you do that?" Others say" GEE...HOW did you do that?" Pictures are attached...
Have fun.
John
demographic, MYB, Stick486 and 3 others like this.
johnnie_dr is offline
post #7 of 21 (permalink) Old 01-31-2016, 09:30 AM
First Name: Keith
I did a table using two pieces of live edge arbutus...but I never thought of adding any stones.
That's a great idea and it looks terrific. Sure would like to see yours when you get it done. Good luck!
cocobolo1 is offline
post #8 of 21 (permalink) Old 01-31-2016, 11:24 AM
Wow! Great job on the routing, John!! :0
post #9 of 21 (permalink) Old 01-31-2016, 12:07 PM
This thread opens a whole new world.HMMMMMMMMMM................................. .......
Herb Stoops is online now
post #10 of 21 (permalink) Old 01-31-2016, 12:36 PM Thread Starter
First Name: Scott.
Well thanks guys, great response and pictures from someone who's actually done it with excellent results.
Jigsaw plywood template, maybe after using one of those scribe wheel things for the correct offset so I can use a guidebush which will allow me to incrementally lower the depth of cut to the correct depth.
I don't want to cut the stones to thickness if I can help it.
I gave her the brief of finding as many different and interesting coloured stones as possible and she really did well.
She found a fair range of stones at the beach, from igneous through metamorphic to sedimentary and even a few bits of well waterworn coloured glass.
I doubt I will be making it too soon but hope to get something like cherry wood for the top and rout out the knots to possibly put stones in where they were so the grain looks like its flowing around the stones.
I'm a site carpenter by trade so not a natural furniture maker.
Got plenty time (realistically years) before I need to do it and finding the stones was just me setting the idea in motion with the hope that she remembers us picking them (bearing in mind the fact I took loads of pictures to remind her, including some of the stone haul in the back if the car to tie the memory into the day).
I'm trying to work out what areas those stones have travelled from to get there as well, just so she has a bit of a story to go with it all.
Converting a Bosch RA1180 to a table LagunaPaul Table-mounted Routing 31 08-11-2014 09:45 PM
Favorite beginner base plate? rfsurfer Table-mounted Routing 43 12-31-2013 04:51 PM
remove table top inserts (Red & Grey)from a Freud Table Top kleinj Table-mounted Routing 0 01-04-2012 06:51 PM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
