Bushings for Triton router - Router Forums
 5Likes
  • 2 Post By lowracer
  • 2 Post By PhilBa
  • 1 Post By CharlesWebster
post #1 of 6 (permalink) Old 02-02-2016, 11:01 PM Thread Starter
Default Bushings for Triton router
It looks as though Triton's TGA150 accessory kit replaces the router base plate to provide a smaller opening to accept bushings.
Given the extortionate price for the Triton kit, can I just change out the base plate with any one that accepts a standard 1-1/4" bushing?
Does anyone have a recommendation for a plate, preferably pre-drilled?
<Chas>
CharlesWebster is offline
post #2 of 6 (permalink) Old 02-03-2016, 12:19 AM
Semipro's Avatar
First Name: John_*
yes buy one or make.
contact ROUTER WOODWORKING he a member he can help you
also here http://www.infinitytools.com/Univers...tinfo/115-030/
Semipro is online now
post #3 of 6 (permalink) Old 02-03-2016, 06:53 AM
katabrontes's Avatar
Use an adaptor then you can use any type of bushes that fit the adaptor.
katabrontes is offline
post #4 of 6 (permalink) Old 02-03-2016, 09:06 AM
Country: South Africa
First Name: Hentie
The official replacement for the TGA150 is the TGA250
Look if you can find the TGA001. I got mine for around 2/5th of the price of the TGA250 a year ago, so it should still be available from your agent
If you look at the following 3 "reference" links, you will see there isn't too much difference between the bunch (definitely not enough to justify multiplying the price by almost 3 to get to the price of the TGA250
Robot Check
Robot Check
Robot Check
jj777746 and CharlesWebster like this.
lowracer is offline
post #5 of 6 (permalink) Old 02-03-2016, 10:32 AM
PhilBa's Avatar
First Name: phil
Another vote for making your own sub base. I have made a lot - probably 5 or 6 just last year. Usually I use 1/4" Lexan but acrylic, BB and other materials are fine too. Use 1 3/8" and 1 3/16" (1 1/4" works in a pinch) forstners to make the hole w/rabbet for the bushing. Oversize the mounting holes so you can center the bushing/base assembly on the router. There are numerous instructions for making them on this forum and the internet in general.
Once you get the hang of making sub bases, you'll find that it's really easy to make task specific jigs to ease almost any router job.
jj777746 and cocobolo1 like this.
Visit my shop website.
PhilBa is offline
post #6 of 6 (permalink) Old 02-03-2016, 12:24 PM Thread Starter
Thanks Hentie, one of the Robot links had what I needed. Thanks all for your suggestions
<Chas>
lowracer likes this.
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
router base and bushings sunny brae General Routing 0 03-23-2011 04:55 PM
Guide Bushings for Triton Router Sliderule Guide Bushings and Templates 8 03-30-2010 10:18 PM
