When Is 1/4" Not 1/4"? - Router Forums
 17Likes
post #1 of 46 (permalink) Old 02-04-2016, 04:14 PM Thread Starter
Default When Is 1/4" Not 1/4"?
Please explain why 1/4" plywood does not fit into a dado cut with a 1/4" router bit. I had to move the fence and rout twice to get the bottom to fit into the dado. Obviously the plywood is to thick, or the 1/4" dado is too narrow. The difference is too small for me to see. Which is more likely?
It's time consuming to have to cut the dado three times (shallow cut, full-depth cut, widening cut). The plywood came from Lowe's. There's nothing special about it.
Name:	Ladder Box 02.jpg
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #2 of 46 (permalink) Old 02-04-2016, 04:25 PM
I think it has to do with different tolerances between sheet goods manufacturers and the finishing they go through? Sanded vs unsanded. Just a guess..
A set of calipers or a micrometre would allow you to determine the exact thickness and choose an appropriate size but I've only ever made multiple passes. More work but a custom fit each time. Good luck!
Sent from my SM-N910W8 using Tapatalk
Semipro likes this.
Brendoniuss is offline
post #3 of 46 (permalink) Old 02-04-2016, 04:42 PM
What kind of plywood is it, Mike?
Sanded one side Fir sheathing?
Not being critical, just looking for more info. I have no problem using sanded sheathing for shop stuff myself.
Can't get decent Hardwood plywood up here on the Sunshine Coast, so if it isn't critical to me...
DaninVan is online now
post #4 of 46 (permalink) Old 02-04-2016, 05:02 PM Thread Starter
Home Depot Special
patlaw is offline
post #5 of 46 (permalink) Old 02-04-2016, 05:30 PM
WTB one (bit or ply) is metric and the other (ply or bit) is Imperial...
save work...
cut the dado on the TS...
post #6 of 46 (permalink) Old 02-04-2016, 05:53 PM
PhilBa's Avatar
First Name: phil
I'm a little confused, you are saying the dado you cut with a 1/4" bit is too small for 1/4" big box plywood? That is completely backwards from what I've seen. Usually the plywood less than 1/4" thick and the dadoes are loose. maybe you had 3/8" which is about 1/16" over 1/4".
Calipers would be a good idea anyway.
Stick486 likes this.
Visit my shop website.
PhilBa is offline
post #7 of 46 (permalink) Old 02-04-2016, 06:20 PM
Ratbob's Avatar
First Name: Jeff
Calipers will tell the tail, but in the link Mike posted the spec sez the 1/4" ply 'Actual Product Thickness' is 0.47" (just over 15/32).
Herb Stoops likes this.
Ratbob is offline
post #8 of 46 (permalink) Old 02-04-2016, 06:25 PM
I saw that too, and thinking closer to 1/2". They should have said "At least /4" thick"
Herb Stoops is online now
post #9 of 46 (permalink) Old 02-04-2016, 06:31 PM
Ratbob's Avatar
First Name: Jeff
I guess great minds think a like Herb, not sure how I got included in that though. I guess even a broken watch is right twice a day.
Ratbob is offline
post #10 of 46 (permalink) Old 02-04-2016, 07:03 PM
First Name: Keith
Sounds like little more than an advertising error. They meant 1/2" it seems.
cocobolo1 is offline
How to route a 1/4" x 1/4" groove in this base. adot45 Guide Bushings and Templates 15 12-04-2015 05:33 AM
STUCK BIT -- Bosch 1604A stuck with a 1/4" shank junky roundover bit corbind General Routing 27 02-24-2014 07:51 AM
Wanted: 1/4" Corian Iceman567 Woodworking Classifieds 3 10-12-2012 10:22 AM
For Sale: Amanda 45 deg 1/4" shank router bit dalepenkala Woodworking Classifieds 0 06-08-2012 07:27 PM
Switching from 1/2" to 1/4" collet Doug5 Starting Off 6 05-07-2012 08:42 AM
