New flush edge helper-tool - Router Forums
 12Likes
post #1 of 17 (permalink) Old 02-11-2016, 07:05 AM Thread Starter
johnnie_dr's Avatar
Default New flush edge helper-tool
Hi Guys & Gals,
I get eNews from a small company that makes interesting and very helpful tools & widgets. FastCap.com
Here's a new widget that will help stabilize your router and bit when doing flush trimming...
Little Lipper - FastCap - Woodworking Tools
I'm not endorsing it...don't have one...just thought it might be of interest to you all.
Johnnie D
johnnie_dr is offline
post #2 of 17 (permalink) Old 02-11-2016, 08:40 AM
Gaffboat's Avatar
First Name: Oliver
Although I like most FastCap products this one looks scary. It puts your fingers too close to the whirly bits for me. Maybe I'm just a wuss (but I do have all my fingers.)
billyjim and Stick486 like this.
Gaffboat is offline
post #3 of 17 (permalink) Old 02-11-2016, 08:42 AM
vindaloo's Avatar
First Name: Angie
I'm surprised they didn't add a guard and shape it more like a handle behind...... wait a minute..... Might have a go at that.
Gaffboat likes this.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #4 of 17 (permalink) Old 02-11-2016, 08:52 AM
Other than the obvious, with your fingers too close to the cutter, you're still unsupported for the first couple of inches until the guide gets to the part. After all those years of trimming backsplashes and panel edges, I just use the flush bit in a trimmer - and with the trimmer vertical, I'd think having it horizontal like that is just asking for trouble as you're trying to balance the weight of the trimmer too. If I was going to make a guide, I'd look at the Flush Trim Jig from Woodsmith #94
Murtu01 likes this.
tomp913 is offline
post #5 of 17 (permalink) Old 02-11-2016, 10:54 AM
Originally Posted by johnnie_dr View Post
Hi Guys & Gals,
Johnnie D
I would fear for my fingers way too much to use that...
Stick486 is offline
post #6 of 17 (permalink) Old 02-11-2016, 11:21 AM
MikeMa's Avatar
Agreed not a safe product. The safest thing to do is orient the work piece so that you hold the router properly in a vertical position.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #7 of 17 (permalink) Old 02-11-2016, 11:28 AM
kp91's Avatar
First Name: Doug
Gents,
I forwarded your feedback on to Mr. Akers, he thanks you for your input.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #8 of 17 (permalink) Old 02-11-2016, 11:32 AM
or make something yourself...
Murtu01 likes this.
Stick486 is offline
post #9 of 17 (permalink) Old 02-13-2016, 05:23 PM
Hi, I am the designer and creator of the Little Lipper. I have been making furniture full time for over 40 years now and have been using variations of the Lipper for around 10 years. The Lipper has been very useful in my work and I always thought it would be a great product which is why I contacted FastCap.
I can see how the Lipper can be perceived to have safety issues but in usage it feels very comfortable to me. The Lipper is 8” long and your hand is a safe distance from the flush cut bit. The force of your hand on the Lipper is directed parallel to the cut and not towards the cutting bit. The combined length of the Lipper and the router gives the user a great deal of leverage and you are also using two hands so you have added control.
I would recommend the Lipper be used with a laminate trimmer since they are smaller and easier to handle, I use a Bosch with a 1/2” bit and usually have that setup as a dedicated router. There are times when the weight of a larger router is helpful but it is usually not needed.
The Little Lipper extremely versatile and will give you a perfectly flush cut on flat, concave and convex surfaces. Other than the cutter depth the trimmer requires no adjustment. The router rotates around the Lipper and once the Lipper is placed on the surface to be trimmed the router is lowered to engage the cut. The cutting depth can be controlled so you don't have to make the full cut in one pass. The added leverage provided by the Lipper is especially useful when you have to cut downhill to prevent chip out when trimming figured woods.
We tried to keep the tool as simple, functional and affordable as possible. We are open to making improvements and welcome your comments. Good luck with your routing projects.
Thanks,
Allen Miesner
miesner.com
kp91, whimsofchaz and cocobolo1 like this.
Aldoman is offline
post #10 of 17 (permalink) Old 02-14-2016, 05:51 AM
Or you could simply use a router that was intended to do such a thing, like the Festool mfk700. It makes this job as easy/safe and dust free as possible.
I worked around this problem for years with different methods and varying degrees of success. An offset fence on a router table works well, but only one smaller parts like shelves and it can't do curved pieces at all. Block planes and card scrapers work too, but they are tedious and slow, not a huge issue to a hobbyist but not when you do it for a living.
Lamello also makes a "lipping planer" that does a fine job, but it is a strictly dedicated tool, that's all it does. The mfk700 has vertical base options that make it far more versatile.
LONGHAIR is offline
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 10:21 AM
Greater than japa62 Jigs and Fixtures 12 01-16-2013 12:03 AM
Jet Tool/ ToolSelect Review The Bench Dawg Tools and Woodworking 2 11-06-2011 08:15 AM
1"x2" pine, what rounding edge router bit do I need for a flush edge? annmariehawkins Router Bits - Types and Usage 5 12-04-2010 12:00 PM
The Marvel 3 in 1 tool from MLCS: base plate and table mount advice please loninappleton Table-mounted Routing 4 07-10-2010 08:32 PM
