Milescraft Guide Bushings - Router Forums
 11Likes
post #1 of 14 (permalink) Old 02-20-2016, 11:25 PM Thread Starter
whimsofchaz's Avatar
First Name: Chuck
Default Milescraft Guide Bushings
A few weeks ago, maybe months ago, I posted a thread talking about the safety of the Milescraft guide bushings. The consensus was that Milescraft was an OK product to use and others had used them for years. Well today while routing some dovetails I had the insert that holds the guide bushing come loose and the guide bushing dove into my bit. Thankfully the bit was carbide and it chewed up the bushing and fouled up a half a days work milling wood and fitting everything for the dovetails. Now my question it seems the plastic insert wiggled loose and came off the face plate. I would like to finish the dovetails so do you guys think it would be OK to tape that plastic insert to the face plate. Of course I will be using the locking mechanism but for extra holding do you think the tape will work. Sorry I was so long winded
whimsofchaz is offline
post #2 of 14 (permalink) Old 02-21-2016, 12:10 AM
NO
JudgeMike and Gaffboat like this.
Herb Stoops is online now
post #3 of 14 (permalink) Old 02-21-2016, 12:49 AM
Bobj3 used to recommend using an o-ring to prevent the guide bushing from loosening up. I think it would be a better choice.
post #4 of 14 (permalink) Old 02-21-2016, 09:09 AM
Garyk's Avatar
First Name: Gary
Anything that fails (especially at router speeds) would go into my trash can. If one part is defective then I would think that maybe the steel being used could have internal defects that I could not see and using it is a chance I would not take. A trip to the ER will be much more costly than spending a few dollars more to buy a top rated bit.
Garyk is offline
post #5 of 14 (permalink) Old 02-21-2016, 04:16 PM
PhilBa's Avatar
First Name: phil
Do yourself a favor and toss them out. Next, make (or buy) a sub base that can take PC style bushings and get the metal ones that have the screw ring. A bit more expensive but, even if you don't get hurt, wasting effort like you did will cost a lot more in the long run. The picture below is of the set I have - woodcraft, $40 but some times on sale for $30. I have and use them all the time. Excellent product.
Visit my shop website.
PhilBa is offline
post #6 of 14 (permalink) Old 02-21-2016, 04:35 PM Thread Starter
First Name: Chuck
I was using the Milescraft insert because I had the face plate for it. I looked around last night and found the face plate that will use the PC bushings so I can throw the Milescraft in the trash. I was just trying to get the project done. I am glad I found the old face plate for my router.
post #7 of 14 (permalink) Old 02-21-2016, 04:41 PM
kp91's Avatar
First Name: Doug
Milescraft
replacement parts are available
Herb Stoops likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 14 (permalink) Old 02-21-2016, 04:46 PM
Gaffboat's Avatar
First Name: Oliver
That's the set I use and I like it because their bushings are only 7/64" long so you can use 1/4" thick templates. I have another set made by a different manufacturer that I seldom use because the length of many of their bushings is 5/8" requiring a thick template.
kp91 and PhilBa like this.
Gaffboat is offline
post #9 of 14 (permalink) Old 02-21-2016, 04:54 PM
kp91's Avatar
First Name: Doug
My cheap woodworking expo purchased long bushings met the belt sander... they work a lot better now!
My lee valley guides (not Porter Cable diameter) had a much shorter length.
1-3/4" Brass Template Guides - Lee Valley Tools
BrianS likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #10 of 14 (permalink) Old 02-21-2016, 05:27 PM
I think quite a few of us have filed or sanded them shorter. Has anyone ever needed one that long? I can't see the point personally.
Oversized guide bushings and storage Mike Guide Bushings and Templates 7 09-04-2016 11:40 AM
what size insert rings for pc guide bushings? Goblu Guide Bushings and Templates 5 03-03-2015 05:22 AM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
Guide Busings and Milescraft signofchange Sign Making 4 02-08-2011 11:15 AM
Harbor Freight Guide Bushings Work Better. RJM60 Guide Bushings and Templates 0 08-02-2010 05:06 PM
