Mortises using 2 Router Guides - Router Forums
 10Likes
post #1 of 16 (permalink) Old 02-26-2016, 02:17 PM Thread Starter
First Name: lee
Default Mortises using 2 Router Guides
I watched this Build a Workbench - Build it with Bosch and they used 2 router guides cutting a mortise. Does it really make it easy or they just selling equipment?
Murtu01 likes this.
coxhaus is offline
post #2 of 16 (permalink) Old 02-26-2016, 02:30 PM
First Name: Ray
Not selling equipment. Two guides will keep the router centered and will rout a straight and even mortises.
If the guide rods are long enough, a second guide is easily fabricated from a piece of hardwood, with two holes bored for the rods, then bore two holes on the top edge for threaded inserts to hold set screws.
I learned the hard way that two guides make accurate mortises.....
Ray Newman is offline
post #3 of 16 (permalink) Old 02-26-2016, 02:57 PM
PhilBa's Avatar
First Name: phil
You can make your own router mortise jig pretty easily.
Here's a really quick-n-simple mortise guide that uses bushings. There are tons of designs out there, some a lot more complex.
Murtu01 likes this.
Visit my shop website.
PhilBa is offline
post #4 of 16 (permalink) Old 02-26-2016, 03:44 PM
One more jig that will quickly mortise the dead center of any edge or narrow face is to take a router base plate and drill and thread a hole equidistant and in line from the plates center hole on either side of it. Screw in a pair of pins (bolts with the heads cut off for example) and set the router and base down on the work piece and rotate until each pin makes contact on opposite sides.
Murtu01 likes this.
post #5 of 16 (permalink) Old 02-26-2016, 04:00 PM
Ghidrah's Avatar
First Name: Ronald
I've seen a couple homemades like the this one before on fin carpenters routers
Cherryville Chuck and Murtu01 like this.
Ghidrah is offline
post #6 of 16 (permalink) Old 02-26-2016, 05:48 PM
https://www.youtube.com/watch?v=ZXEvRoW8lY8
you bet your zippy it makes it easy...
I do it that way often...
at some point. if you do a lot of routering, having more than one router is a major plus too....
Murtu01 likes this.
Stick486 is offline
post #7 of 16 (permalink) Old 02-26-2016, 06:20 PM
it's a lot easier to install two nylon bushings/spacers (held in place w/ button/cap head screws) in opposing screw holes...
Murtu01 likes this.
Stick486 is offline
post #8 of 16 (permalink) Old 02-26-2016, 08:16 PM Thread Starter
First Name: lee
OK so I want one. Does Bosch sell a dual router guide for the Bosch 1617evspk?
coxhaus is offline
post #9 of 16 (permalink) Old 02-26-2016, 08:30 PM
not that I know of...
so get a full kit and a bare bones....
Stick486 is offline
post #10 of 16 (permalink) Old 02-26-2016, 10:35 PM
Honored Member
First Name: pat
Something I've been doing for >25 years.
The only way to router mortice.
Murtu01 likes this.
Quillman is offline
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
