Freud FT2000E base clearance - Router Forums
 1Likes
  • 1 Post By Gene Howe
post #1 of 5 (permalink) Old 02-26-2016, 04:15 PM Thread Starter
First Name: Ben
Default Freud FT2000E base clearance
Hi,
Can anyone measure the clearance of the FT2000E router from the base plate to the collet in the full plunge position for me?
I haven't used mine in a long time and the plunge mechanism just doesn't seem to be traveling all the way down. I see 1.5" distance between the base plate and the bottom of the collet. That is a real problem.
If that isn't right, any suggestions how to fix it?
Thanks!
--Ben
bcconner is offline
post #2 of 5 (permalink) Old 02-26-2016, 04:47 PM
Gene Howe's Avatar
First Name: Gene
No need to measure. I know that mine will plunge to the base plate.
Is your turrets and stop rod adjusted for full plunge?
Cherryville Chuck likes this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 5 (permalink) Old 02-27-2016, 11:36 AM Thread Starter
First Name: Ben
Thanks. I took the base off the body this morning and found a rats nest of crud buildup in one of the posts. Cleaning that mess up took care of the original question.
Unfortunately it still didn't go down far enough to clear the 5/8" Freud template guide with the dovetail bit I was going to use. I picked up a used Leigh dovetail jig a while back and decided to try to use it. The bit only extends about 1/4" below the bottom of the guide. I'm assuming I will need a standard 1/2" dovetail bit?
--Ben
bcconner is offline
post #4 of 5 (permalink) Old 02-27-2016, 12:29 PM
I agree with Gene. I had one and I'm sure that if i put it on a bench and pushed down the collet nut would hit the bench. On my Hitachis one column is longer than the other. If one of yours is longer is it possible you reversed it when putting it back together?
post #5 of 5 (permalink) Old 02-27-2016, 04:23 PM Thread Starter
First Name: Ben
Got to looking at what was in the bit box that came with the jig vs what is in the user guide...and the dovetail bit was waaay shorter than it should have been. Apparently someone swapped it out for a shorter one before I got it. All righty now.
None of the local stores had a standard #90 Leigh compatible bit, so I ordered one online.
Thanks, guys!
--Ben
bcconner is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Freud sub base plate vinnieroute New Member Introductions 2 07-08-2013 10:40 AM
Bosch MR 23 and Milescraft Turnlock base? achoox4 Guide Bushings and Templates 9 04-10-2013 05:48 AM
Freud FT1760 Plunge Base Art Korfmann General Routing 8 09-04-2009 03:04 PM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
