upcut router bit in table mounted router - Router Forums
 1Likes
  • 1 Post By neville9999
post #1 of 4 (permalink) Old 03-04-2016, 01:47 PM Thread Starter
Default upcut router bit in table mounted router
Greetings!
I generally cut mortises in a hand held router using a Mortise Pal, but the latest project requires deep mortises that the MP jig won't do. Tried cutting them in table mounted router and the upcut bit "grabbed" the test piece. I was feeding the piece right to left as normally do. Do I have to go left to right in a table mounted router with an upcut bit?
tia
hilcntry
hilcntry is offline
post #2 of 4 (permalink) Old 03-04-2016, 03:16 PM
Semipro's Avatar
First Name: John_*
remember that when you cut a mortise one side of the cut will be a climb cut, ( no matter which way you push it) only way to control the cut is to take shallow cuts
Semipro is online now
post #3 of 4 (permalink) Old 03-04-2016, 03:42 PM
You are usually better off to remove as much of the waste as possible by drilling instead of routing.
post #4 of 4 (permalink) Old 03-05-2016, 03:11 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
You have to cut it out a small amount at a time, the cutter just cant take the load so I plunge cut the waste out and only clean up the mortise once all the waste is gone. N
Stick486 likes this.
neville9999 is offline
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
