How to clean a DW735 planer? - Router Forums
 15Likes
post #1 of 19 (permalink) Old 03-05-2016, 10:59 AM Thread Starter
creative's Avatar
Default How to clean a DW735 planer?
fellow sawdust makers,
I recently bought some Birch strips at Home Depot for a furniture project. Peeled off the sticker labels with my chisel, but some sticker glue was left on the wood. Ran all the wood through my DW735 planer.
Currently, there's some sticker glue stuck to the metal plate that the wood feeds across. And there's a good chance some is on the rollers.
What should I use to clean the metal plate and rollers? Mineral spirits? Denatured Alcohol? Something else?
As always, thanks for your help!
creative is offline
post #2 of 19 (permalink) Old 03-05-2016, 11:05 AM
I would try the mineral spirits. If the rollers have a rubber coating I would definitely avoid the alcohol. Alcohol could dry the rubber out.
peterjmartin and creative like this.
post #3 of 19 (permalink) Old 03-05-2016, 12:14 PM
First Name: Jerry
I use mineral spirits on the rollers on my 735. When I had the 734, the rollers needed cleaning quite often due to that model not having the blower, or so I suspect the reason was that they kept needing to be cleaned and would not feed the material through the planer until the rollers were cleaned.
The 735 seems to be the favorite planer of most of the members of the forum, I am pretty sure that you will like your's too.
Jerry
creative likes this.
Jerry Bowen is offline
post #4 of 19 (permalink) Old 03-05-2016, 01:22 PM
vchiarelli's Avatar
First Name: Vince
Any time I have to clean off labels, etc. from any item I use Goo Gone - works like a charm
Goo Gone
BrianS and creative like this.
vchiarelli is offline
post #5 of 19 (permalink) Old 03-06-2016, 03:35 AM Thread Starter
creative's Avatar
Chuck - just did some poking around the internet to see if mineral spirits damage rubber. As far as I can tell, mineral spirits can damage rubber, but it depends on how long they're contacting the rubber, and what type of rubber it is.
One of the reasons I asked is I bought some used equipment with spraypaint on it once. I bought some spraypaint remover to take it off. Some minutes later, I lightly scraped a screwdriver over the paint, to see if it would flake off. To my surprise, the screwdriver dragged a shallow ditch on the surface of some plastic parts of the equipment. The paint remover had literally turned plastic into a semi-soft gel.
So I'm still a little concerned about using mineral spirits on the rollers of the DW735. Wouldn't want sticky glue removal to spiral into a bigger/more expensive problem.
Maybe I'll contact Dewalt an see what they recommend - unless you and others have some anecdotal info about personally using mineral spirits on the DW735 without any issues
creative is offline
post #6 of 19 (permalink) Old 03-06-2016, 06:56 AM
Gene Howe's Avatar
First Name: Gene
You might try plain Simple Green and a damp rag. Maybe 409 instead would work. I don't think either would damage the rollers.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #7 of 19 (permalink) Old 03-06-2016, 08:26 AM
First Name: Art
You have to keep the rollers clean otherwise the wood will have a hard time being pulled through. To clean mine I have always used mineral spirits. After many years and many cleanings the rollers still look like new.
mgmine is offline
post #8 of 19 (permalink) Old 03-06-2016, 11:55 AM
Contacting DeWalt is probably your best bet. Without knowing exactly what the rubber compound is it's hard to be sure what will clean it without potential harm. Most of the suggestions so far probably won't hurt the rollers if you just wipe the goo off and then wipe the roller dry or maybe also wipe with a damp cloth after for the ones that are water soluble. All bets are off if the solution is allowed to sit for a while as it may have time to migrate into the rubber then and the effects might not show up right away. I've seen orange cleaner spilled on melamine coated particle board for example that dissolved the melamine coating because it didn't get caught right away.
post #9 of 19 (permalink) Old 03-09-2016, 11:30 AM Thread Starter
creative's Avatar
Chuck (and everyone else on the thread),
I sent an email to Dewalt, an they got back to me today. They said:
"We do recommend cleaning the rollers with mineral spirits oil, as this will help the rollers keep the tacky feeling to help grab the materials. The mineral spirits will not cause damage."
So it looks like it's time to buy some mineral spirits. Thanks for all the helpful comments everyone, and stay dusty.
DesertRatTom likes this.
creative is offline
post #10 of 19 (permalink) Old 06-12-2016, 03:27 PM
First Name: Nicholas
I picked up my DW 735 via Craig's List. Guy was asking something like $300 for it (great price!). Went out to see it. Looks nice. He fires it up to show it off to me. Grabs a scrap of prefinished flooring (prolly with an aluminum oxide finish, to boot) and [tries to] runs it through the the planer. A little smoke as he pushed it through the planer. Wood comes out burned and not a great finish. He instantly dropped the ask to $175 without my even asking him to.
Done deal [gloat].
Took it home. The rollers were gummed up considerable. Cleaned them up with mineral spirits. Swapped in a new set of blades. Voila! Planer like new.
DesertRatTom and Bob Adams like this.
Nicholas Carey is offline
Dewalt DW735 planer carbide knives Jack Wilson Tools and Woodworking 7 10-07-2013 08:16 PM
Keep Those Rollers On Your Planer Clean Jerry Bowen Tools and Woodworking 10 04-17-2013 06:53 PM
Clean The Rollers On The Planer Jerry Bowen Tools and Woodworking 0 04-20-2012 11:24 AM
In Findlay Ohio- act fast- DW735 planer $400 kp91 The Bargain Bin 0 01-30-2010 03:06 PM
