Metric conversion? Oh No! - Router Forums
 85Likes
post #1 of 78 (permalink) Old 03-11-2016, 11:39 PM Thread Starter
Talking Metric conversion? Oh No!
Every time I try to work with metric, I find myself stuck at some point. Well, having grown up with the imperial system, it always surprises me how difficult the Metric system seems to be to use her in the U.S.A. Now, I've stumbled upon and article that pinpoints why it is such a hassle to me, to use metric. Read on and comment if you will. (From Wikipedia)
One common complaint about the metric system is that it doesn't provide a natural way to divide things into thirds; even dividing things into quarters requires one to go down two levels, instead of just one, in the system of units, since 0.25 is the decimal that represents 1/4.
The metric system did not divide the day into 100,000 parts; instead, the hour, minute, and second were retained to allow the day to be divided neatly into quarters and thirds.
In response to an instance of the occasionally-heard suggestion that the metric system should have been built on base 12 instead of base 10, it occurred to me that the precedent of an everyday unit, the day, standing in such a relationship to the metric unit, the second, that the day can be exactly divided into 27 parts, each of which consists of an even number of seconds (3200 seconds, or 53 minutes and 20 seconds), one could, for example, use as everyday units a metric pound of 453.6 grams (instead of approximately 453.69 grams) and a metric inch of 2.52 centimeters (instead of 2.54 centimeters).
453.6 grams divides evenly into 81 units of 5.6 grams, and also into 7 units of 64.8 grams - and, for that matter, into 8 units of 56.7 grams. 2.52 centimeters divides evenly into 9 units of 0.28 centimeters, and also into 7 units of 0.36 centimeters - and, for that matter, into 4 units of 0.63 centimeters.
However, I can't really expect that this very wild idea of using this metric pound and metric inch as everyday units, and measuring things out in these pounds and inches, so that they can be evenly divided into thirds, ninths, and sevenths if one uses the regular metric scale, would catch on.
Back to me... There, now I understand why thinking Imperial clashes with measuring metric.
Water and oil. Matches and gasoline.
post #2 of 78 (permalink) Old 03-12-2016, 12:16 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
That whole article is based on wrong info. check out the link below.
having spent the first 30 years of my life with imperial, and then another 30 in a country that had both (you could buy a half inch garden hose but it had to be 20 metres long, if you wanted a kilo bag of sugar you drove a mile to buy it, etc. etc.) and finally 8 years now in a solely metric country, I can tell you why you have trouble with metric.
Its not your first language. Just like being bi lingual, you can be fluent in languages, but you will always think in your first one.
I am comfortable now with metric, I dont even have an imperial measure any more, but if I need to describe something to someone, my brain will always come up with 2 foot long, never 60cm or 600mm. Those number require thought.
Why is a minute divided into 60 seconds, an hour into 60 minutes, yet there are only 24 hours in a day? - Scientific American
kp91 and Herb Stoops like this.
sunnybob is online now
post #3 of 78 (permalink) Old 03-12-2016, 12:23 AM
First Name: Keith
Why should we always have to think in 1/4's, 8ths, 16ths, 32nds, 64ths, 128ths, 256ths. 512ths etc. What's wrong with 10ths?
You and I have been raised imperially, not metrically. But the metric system is extremely easy once you use it for awhile.
What you have to do is to forget imperial when you are working with metric. It's really quite straight forward.
One day, the U.S will go the way of the rest of the world...metric.
Cherryville Chuck likes this.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #4 of 78 (permalink) Old 03-12-2016, 12:33 AM
plans call for Imperial use Imperial measuring devices...
do it the same way for metric and don't about conversions...
post #5 of 78 (permalink) Old 03-12-2016, 12:35 AM
First Name: Keith
Originally Posted by stick486 View Post
plans call for imperial use imperial measuring devices...
Do it the same way for metric and don't about conversions...
prezackly!
Shop guy and jj777746 like this.
post #6 of 78 (permalink) Old 03-12-2016, 06:48 AM
vindaloo's Avatar
First Name: Angie
Glad Stick said that. I use both and I was bought up mainly with metric. My dad used imperial, he was an apprentice engineer draughtsman in the late 50's, early 60's and use imperial then and in his woodworking. So I saw that side and then at school metric had just come in so I learned that. Now I use whatever is suitable for the situation.
I get the problem dividing 10 by 3 in engineering, but in carpentry is there really a problem? After all a third of a mm is a sneeze out.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #7 of 78 (permalink) Old 03-12-2016, 08:13 AM
Hutzul's Avatar
I trained as a mechanical engineer in the early 1970's, where at college we were told to forget imperial and we were taught in metric. However back at work as a toolmaker we worked in imperial, so like vindaloo ' Now I use whatever is suitable for the situation'.
I prefer to use metric, especially when the calculator is in play.
Shop guy and cocobolo1 like this.
Hutzul is offline
post #8 of 78 (permalink) Old 03-12-2016, 09:06 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
You are overly complicating it as Metric is as easy as it gets so just forget all that can't divide pounds with rubles. Oh and when you get a minute can you tell me what a 1/3 of 11/64ths is? N
jj777746 likes this.
neville9999 is offline
post #9 of 78 (permalink) Old 03-12-2016, 09:11 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Metric is base ten because men (and women) have 10 fingers - it is as simple as that.
I use both systems and quickly recognize the comparative stupidity of the imperial system.
An inch is 1/12th of a foot and neither one of those has anything whatsoever to do with a pound or an ounce.
And still neither of those has anything whatsoever to do with quarts or gallons. Imperial is a goofy system and after a long career in engineering, I can honestly say that one spends quite a bit of time making volumetric and weight calculations.
The basic metric unit of measure is the meter. 1/100 is a centimeter and 1/1000 of the meter is a millimeter.
Using water (the standard in chemistry & physics), one cubic centimeter weighs one gram. Just as simple as that proves the stupidity of imperial units of measure. Therefore, one liter of water, weighs one kilogram.
Now, try that with inches and feet vs. pounds or ounces vs. quarts and gallons and those of you who are metric naysayers have just proven that you have a deep lack of understanding of this inherent simplicity.
My products are sold globally and fortunately most of the planet uses metric. Rather than sit-around and gripe about it, I chose to embrace the system and see it for what it really is...SMART!
OPG3
Tweak everything!
OPG3 is offline
post #10 of 78 (permalink) Old 03-12-2016, 09:17 AM
Gaffboat's Avatar
First Name: Oliver
Although I do most everything with imperial measurements, I often resort to metric for my projects when I need precision that's easy to measure and to add and subtract.
Gaffboat is offline
Metric Router Lift Availability plunger Table-mounted Routing 19 03-08-2014 09:17 PM
Availability of Metric Spiral Upcut Bits in the US? williaty Router Bits - Types and Usage 13 01-13-2014 07:27 AM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
making and accurate template for an oval hand mirror bob oswin Jigs and Fixtures 31 01-20-2009 07:36 PM
Trying to go metric you have convinced me, help me get them dovetail_65 Guide Bushings and Templates 15 01-12-2009 02:44 PM
