Plunge bit leaves ridge in mortis... - Router Forums
 1Likes
post #1 of 18 (permalink) Old 03-15-2016, 03:56 PM Thread Starter
First Name: Kyle
Default Plunge bit leaves ridge in mortis...
Hi all:
I'm trying to make some mortises with a 1/2" plunge bit and it leaves a distinct ridge in the same place every time. By this, I mean that the bottom of the mortis is noticeably smaller than the top.
I thought it was being caused by me trying to do the cut in two passes, but when I tried one, I had the same result.
More experimentation (by making a very shallow cut) suggests that the first 3/8 of the bit cuts about 1/32 less than 1/2". I can't see any obvious damage to it, though.
Am I doing something wrong here? Seems like this should be easy.
Thanks...
Wyomingclimber is offline
post #2 of 18 (permalink) Old 03-15-2016, 04:00 PM
Nickp's Avatar
First Name: Nick
Measure the bit diameter...?...top and bottom...?
Also...unplug router, grab bit by the end...any play...?
Nick
Nickp is offline
post #3 of 18 (permalink) Old 03-15-2016, 05:10 PM
Originally Posted by Wyomingclimber View Post
Hi all:
I'm trying to make some mortises with a 1/2" plunge bit and it leaves a distinct ridge in the same place every time. By this, I mean that the bottom of the mortise is noticeably smaller than the top.
Thanks...
welcome to the forums Kyle...
who made the bit???
what style is it...
Stick486 is offline
post #4 of 18 (permalink) Old 03-15-2016, 05:16 PM
Welcome to the forum Kyle.
post #5 of 18 (permalink) Old 03-15-2016, 05:36 PM
hawkeye10's Avatar
First Name: Don
There just has to be a common sense answer to this. I wish I had some common sense.
Kyle welcome to the forum. Knowing these guys here someone will have an answer for you.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 18 (permalink) Old 03-15-2016, 06:22 PM
gjackson52's Avatar
First Name: Gary
Welcome to the forum !
Gary
gjackson52 is offline
post #7 of 18 (permalink) Old 03-15-2016, 07:20 PM Thread Starter
First Name: Kyle
Thanks for the welcomes!
This is a Witeside UD5160 1+1 1/2"x1/2" Carbide Compression Spiral Router Bit bought new off eBay.
I can't reliably get calipers on it because of the design. There's no play. I actually took out out, replaced it and cut a new hole.
It appears that the ridge is created at the transition between the first spiral and the second--as though that first spiral section is cutting 1/32 too small.
Is that feasible? I tend to not like to blame my tools, but the fact that all my mortises transition to a smaller width at exactly the same place is a bit suspicious.
Also, I tried a Freud 1/4" spiral bit (different collet, but otherwise same setup) and it worked fine.
I can clean up the problem with a chisel, but man, I don't want to...
post #8 of 18 (permalink) Old 03-15-2016, 07:39 PM
Honored Member
First Name: pat
All compression bits leave a transitional anomaly on the work.
Change to a straight or up-spiral if you must.
And keep those stabs (cutting increments) to <3/16"/stage.
What router are you using?
Quillman is offline
post #9 of 18 (permalink) Old 03-15-2016, 07:45 PM Thread Starter
First Name: Kyle
Interesting! What's the point of that? Seems irritating.
I'm using a DW618...
post #10 of 18 (permalink) Old 03-15-2016, 10:12 PM
Honored Member
First Name: pat
It's not intentional; it's the consequence of the grind.
Lots of stress on the cutter during its production (aggravates the condition); it's a miracle
they work as well as they do.
Moreover, the substrate they're used on is usually such that the anomaly is of little consequence (ply-woods).
On close inspection you'll find the transition is a stress riser (high point).
Use a cheap straight solid carbide. Exotics are full of surprises.
If you're using the fixed base you're asking for multi-depth adversity.
Use the 6182.
Routers
Quillman is offline
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
STUCK BIT -- Bosch 1604A stuck with a 1/4" shank junky roundover bit corbind General Routing 27 02-24-2014 07:51 AM
Can I safely use a plunge bit on a router table? jackstraw Shop Safety 11 10-09-2013 07:04 AM
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 08:49 AM
How to Make A Stand Alone Bookend Set learnexperience Jigs and Fixtures 2 08-04-2011 03:22 AM
