What size wrenches for Bosch 1617 - Router Forums
 10Likes
post #1 of 19 (permalink) Old 03-16-2016, 09:13 PM Thread Starter
First Name: Johnny
Default What size wrenches for Bosch 1617
I can't find my wrenches to change bits. I'm not sure if I even got them because i could have put the bit in before mounting it into the Lift with a crescent wrench. Anyway they're nowhere to be found now and I have every wrench to every router I own in one spot except these.
I would also like to find a bent one for working in the lift if I knew the size.
JohnnyB60 is offline
post #2 of 19 (permalink) Old 03-16-2016, 09:34 PM
16mm for the shaft..
24mm for the collet nut...
both wrenches are very thin...
if you did not receive your wrenches contact Bosch for replacement...
JohnnyB60 likes this.
post #3 of 19 (permalink) Old 03-16-2016, 09:37 PM
for your offset wrenches...
Shop Bosch Offset Router Bit Wrenches (Pair) at Lowes.com
post #4 of 19 (permalink) Old 03-16-2016, 09:47 PM Thread Starter
First Name: Johnny
Thanks Stick, I guess I'm going to call over to Lowe's to see if they have them in stock and run over there tonight if they do. I didn't realize that they were two different sizes and I just can't remember putting in the bit for the first time. This is the first time I've needed to change the bit.
post #5 of 19 (permalink) Old 03-16-2016, 09:49 PM
you had the wrenches to put the bit in the 1st time...
Ray Newman and DaninVan like this.
post #6 of 19 (permalink) Old 03-16-2016, 10:14 PM Thread Starter
First Name: Johnny
Ya I guess your right Stick, because I can't find a lock to keep the shaft from turning like on the PC. I just don't know what I did with them. Well I guess i look a little harder.
Lowe's doesnít carry them in stock and it will take too long ship.
post #7 of 19 (permalink) Old 03-16-2016, 10:18 PM
automotive parts supply tappet wrenches...
go here and hit the buy now button...
https://www.boschtools.com/us/en/bos...a1152-55590-p/
post #8 of 19 (permalink) Old 03-16-2016, 10:41 PM Thread Starter
First Name: Johnny
I found them, I guess I threw them in the Bosch box for some reason. Good thing I didn't toss it yet. I usually hold onto the boxes of things i buy just in case I need to send it back for some reason.
post #9 of 19 (permalink) Old 03-17-2016, 11:33 AM Thread Starter
First Name: Johnny
I decided to mark all my router wrenches so I know which is for what and realized that Iím still missing a couple of wrenches. One I know I bought is an offset wrench for my PC 890 and canít find it anyplace. I donít know why it would ever be moved from the table.
I also canít find the wrenches for my old 1/4" Craftsman router that I inherited from my dad. I use it probably more than any of my other routers because itís always ready to go with a 1/2 in straight bit in it. Now that my PC is freed up, Iíll probably use it more.
papasombre likes this.
post #10 of 19 (permalink) Old 03-17-2016, 11:42 AM
If you got rid of all the other than Bosch routers you'd create more shelf space and there'd be no wrench confusion!
DaninVan is online now
table/adjustment questions for Bosch 1617 and MR 23 enthusiasts achoox4 Table-mounted Routing 5 06-20-2014 03:38 PM
Self pinging of router fails below MTU size in putty livin Lobby 14 12-23-2012 09:46 PM
bit shank size fred 88 Router Bits - Types and Usage 2 04-18-2011 09:32 PM
Replacement Wrenches for Bosch 1617 Needed dbishopbliss General Routing 8 07-25-2009 08:50 PM
What size is it? Thread size... mountainguy Tools and Woodworking 1 08-20-2006 02:02 PM
