Tapered Legs - Router Forums
 8Likes
  • 2 Post By Stick486
  • 3 Post By Stick486
  • 2 Post By Herb Stoops
  • 1 Post By patlaw
post #1 of 8 (permalink) Old 03-20-2016, 09:40 PM Thread Starter
Default Tapered Legs
Is there a way to taper the lower 8" of legs for a night stand or table using a router? (I don't have a table or track saw.) I'm guessing that the legs are 1-1/2" x 1-1/2". He never says.
Colin Knecht's Standing Table
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #2 of 8 (permalink) Old 03-20-2016, 10:03 PM
sure there is..
clamp the leg in a taper jig exposing how much you want to remove for the taper..
use the jig upside down w/ your router and a top bearing trim bit...
run the bearing along the edge of the jig's base plate..
or....
no jig...
clamp the leg to straight edged piece of the ply exposing how much you want to remove for the taper..
run your router and a top bearing trim bit from the plywood side w/ the leg underneath...
Herb Stoops and jj777746 like this.
post #3 of 8 (permalink) Old 03-20-2016, 10:07 PM
imagine this or a variation there of...
use the router from the bottom side...
don't fprget to use clamps...
post #4 of 8 (permalink) Old 03-20-2016, 10:27 PM Thread Starter
Are you saying to run the leg between the router bit and the fence?
patlaw is offline
post #5 of 8 (permalink) Old 03-20-2016, 10:54 PM
NO, I am not...
directions were for free hand...
look at the jig and ignore the TS...
there is nothing stopping you from using an RT in pattern mode...
add toggle clamps to the topside of the jig for this...
post #6 of 8 (permalink) Old 03-20-2016, 11:50 PM
You wouldn't have to use a fence on the router table like Stick is talking about. The bearing runs against the jig or template.
Stick486 and jj777746 like this.
Herb Stoops is offline
post #7 of 8 (permalink) Old 03-21-2016, 05:11 AM Thread Starter
Got it. Thanks.
jj777746 likes this.
patlaw is offline
post #8 of 8 (permalink) Old 03-21-2016, 08:14 PM
First Name: George
Another easy way to do make a short taper is to rough cut the taper with a bandsaw and clean it up with a hand plane.
Gsamiotes is offline
How To: Attach legs AND 45 Degree Cut 1x1? Psychbiker Table-mounted Routing 9 01-15-2015 08:55 AM
uneven legs r6264 Tools and Woodworking 18 04-24-2014 10:08 AM
Question About Table Legs? Jerry Bowen Lobby 12 03-03-2014 11:28 AM
Have You Watched This Demo On Tapered Legs Jerry Bowen Tools and Woodworking 10 09-10-2013 07:28 AM
template jig for making tapered legs asrubin Jigs and Fixtures 3 04-12-2008 06:40 PM
