Bearings for Elu routers - Router Forums
 1Likes
  • 1 Post By BrianS
post #1 of 9 (permalink) Old 04-17-2016, 10:46 AM Thread Starter
Question Bearings for Elu routers
Hi there,
I have an Elu MOF31 router that I purchased not long ago on eBay.
A week or two ago the motor became overheated, started slowing down and eventually damaged the top bearing beyond repair.
With some assistance, I've managed to completely dissemble the router and checked over the armature and outer windings.
The outer windings give me an identical resistance for both sides.
The armature was giving me low readings for all except one bar on the commutator, which was 60ohms, rather than 3-4 ohms. By straightening out the joint between the commutator and the wire, it's now gone down to about 10ohms.
The problem is that the top bearings no longer seem to be available in the UK.
I wondered whether this part was really any different to those fitted to other Elu or derivative routers and whether I could fit one that is available for a later model?
The other way is for somebody to measure and match the bearing itself to a generic one somewhere.
Hopefully someone here knows what I'm talking about! Would rather get it going again than shell out for a new router. I would imagine it might have a lot more life left in it if I look after it from now on.
Pipeline79 is offline
post #2 of 9 (permalink) Old 04-17-2016, 11:14 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Use a magnifying glass on the bearing. Most bearings have the size stamped on them (outside diameter, inside diameter, thickness)
Or take the bearing to any automotive parts supppliers. Seems like youre in the UK, so there must be a Halfords near you.
sunnybob is online now
post #3 of 9 (permalink) Old 04-17-2016, 12:03 PM Thread Starter
Yes, in the UK. Will take a look. Good idea.
post #4 of 9 (permalink) Old 04-17-2016, 12:38 PM Thread Starter
Hmmm. All I can see is 1, GMN, 6001 and GERMANY... The other side is covered in burnt plastic.
post #5 of 9 (permalink) Old 04-17-2016, 12:40 PM
Try a motor repair shop, they can usually come up with the right bearings , or at least guide you to where you can get them.
Herb Stoops is online now
post #6 of 9 (permalink) Old 04-17-2016, 12:58 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I think this old thread will help you.
http://www.routerforums.com/general-...placement.html
If you go to your profile page and update where exactly you are, we might be able to help you more.
post #7 of 9 (permalink) Old 04-17-2016, 02:05 PM Thread Starter
Thank you for pointing me to that, I've ordered a new bearing from eBay just now.
Best Regards.
post #8 of 9 (permalink) Old 04-17-2016, 04:53 PM
BrianS's Avatar
First Name: Brian
Welcome to our little corner of the 'net.
I just did a google search for the number you saw, it looks like a pretty common bearing. But, since you have already ordered one, you already know that.
Stick around a while.. lots of information available here.
Roy Drake likes this.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 9 (permalink) Old 04-18-2016, 04:36 PM
dalboy's Avatar
First Name: derek
Best Regards.
You could always try Kent Bearings Unit 128 John Wilson Business Park, Harvey Drive, Whitstable, CT5 3QY
If in doubt take the old one with you
They are not to far from you the 6001 is the number you need and it will need to be sealed both sides.
I use to repair tools before having to pack up work
dalboy is offline
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
Things You Need To Know About Woodworking Routers learnexperience General Routing 11 10-16-2011 04:55 PM
