Bosch 1617 Parts Question - Router Forums
 1Likes
  • 1 Post By vchiarelli
post #1 of 4 (permalink) Old 04-26-2016, 08:09 PM Thread Starter
vchiarelli's Avatar
First Name: Vince
Default Bosch 1617 Parts Question
Using my 1617 the other day, noticed that a part (nut) had come loose. Part # 29 in the diagram labeled as "Nut" was loose and sitting above the collet.
Tried to tighten it up but found there was very little room to get two wrenches in there. I'm guessing this should be more than "finger tight". Any suggestions?
Name:	1617 parts list.JPG
routerbitron likes this.
vchiarelli is offline
post #2 of 4 (permalink) Old 04-26-2016, 08:11 PM
that's a 1st...
call Bosch...
Stick486 is offline
post #3 of 4 (permalink) Old 04-27-2016, 12:26 PM
bcfunburst's Avatar
First Name: Reg
Default Tightening loose nut
From your diagram, I have to think you are meant to use one wrench on the nut #29, and another wrench on the top nut #32. That's just a guess; but if you do not have any repair manual, it might be worth a try. Please let everyone know your end results. Best of luck to you.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #4 of 4 (permalink) Old 04-27-2016, 09:38 PM Thread Starter
vchiarelli's Avatar
First Name: Vince
Reg - access to the top nut would require removing the motor from the housing. Not prepared to do that - going to call Bosch CS - didn't get time to do that today.
Thanks for the suggestion.
Bosch 1617 electric cord WSC General Routing 13 03-18-2014 08:16 PM
Bosch 1617 fixed router base rbh11g Table-mounted Routing 7 11-05-2012 12:46 PM
Bosch 1617 Router JRay44 Table-mounted Routing 3 08-29-2012 10:22 PM
Bosch 1617 with Oak Park table kawisser Table-mounted Routing 25 09-08-2011 06:09 PM
New member question about trouble with a Bosch 1617 EVS SD tinkerer New Member Introductions 5 09-26-2009 05:07 PM
