I smoked a plunge bit??? - Router Forums
 9Likes
post #1 of 21 (permalink) Old 04-27-2016, 07:07 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default I smoked a plunge bit???
I was using a MLCS 3/4" plunge bit and boring a hole in the end grain grain of cherry. Smoke came out from the very beginning. This bit had only been used to bore three holes in red oak. The router was level to the work and the speed was wide open. So in your opinion what happened?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 21 (permalink) Old 04-27-2016, 07:50 AM
tannin on the bit from the oak...
too fast...
cherry burns really really easy...
mid level bit...
post #3 of 21 (permalink) Old 04-27-2016, 07:56 AM
Don, plunge cutting into end grain is one of the toughest cuts you can make and a 3/4" diameter bit means you are removing a lot of material.
post #4 of 21 (permalink) Old 04-27-2016, 08:17 AM
Nickp's Avatar
First Name: Nick
Does the bit have cutters on the bottom face and are they clean and sharp...? A straight bit that does not have cutters on the bottom face will only cut with the side cutters...
...just thinkin' of the basics since you said it started to smoke right away...
Nick
Nickp is offline
post #5 of 21 (permalink) Old 04-27-2016, 08:30 AM
Honored Member
First Name: pat
More than likely the cutter is not a plunge cutter.
That is, the end flutes don't over lap, like those found on solid carbide spirals do.
As such, that cutter has too move (laterally) as it cuts or it will burn out just like yours did.
In doubt? put a similar cutter in the drill press and plunge ~1/8". If the center of the cut is uncut, do not plunge this cutter unless you move it at the same time you plunge.
Routing.
Quillman is offline
post #6 of 21 (permalink) Old 04-27-2016, 10:15 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Routing.
This is the bit I was using. #7755 I called MLCS this mourning and the guy said end grain boring was very hard on bits and cherry was one of the worst. He said send it back and they would replace it. "That is good" I don't think I will send it back because it may not be their fault. I want to be fair.
MLCS Plunge Cutting Straight Router Bits
post #7 of 21 (permalink) Old 04-27-2016, 10:28 AM
Don,
What I want to know is --How did you keep it lit??
I smoked a titanium bit on hickory. It wasn't hard to do. Will have to use it on something small to see if it's totally ruined, or still got some life yet.
I had an Amana bit shatter and Toolstoday replaced it - albeit grudgingly. For the price MLCS has on those, I would have to question the original quality to begin with. Are they a name brand or generic house bits? Take the new one if they're offering.
HJ
honesttjohn is offline
post #8 of 21 (permalink) Old 04-27-2016, 10:36 AM
Don, try slowing down the speed on the bit, and slowing the plunge rate on some scrap material.
myself I would use a Forster bit ,or an Irwin Speedbor Irwin Industrial Tool Speedbor 1" Max Speed Drill Bit 3041007 by Irwin Industrial Tool for $8.99 in Power Tool Accessories - Power Tools & Accessories - Tools : Rural King bit to do the job,depending on the project. You might try to bore a smaller hole first, then plunge the larger bit.
You can get those bits in 3/4" or smaller too.
Herb Stoops is online now
post #9 of 21 (permalink) Old 04-27-2016, 11:05 AM
Honored Member
First Name: pat
You're right Hawkeye, it is a so called end boring cutter.
However, because there is so little flute relief (on the end), they do a poor job of end boring in situ.
This is a buyer beware issue. Spirals, steel or carbide, can & are usually ground for end boring in situ.
I'd take the replacement, but in the next time you use the bit, move it.
TwoSkies57 likes this.
Quillman is offline
post #10 of 21 (permalink) Old 04-27-2016, 05:04 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Pat I don't understand "situ". I am a big dummy on understanding computer lingo.
DaninVan likes this.
Can I safely use a plunge bit on a router table? jackstraw Shop Safety 11 10-09-2013 07:04 AM
Sears Router bit description gary smyth Jigs and Fixtures 4 07-18-2011 12:38 AM
Sears Router bit description gary smyth General Routing 1 06-30-2011 10:23 PM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 09:20 PM
