How can I make this post cap? - Router Forums
 4Likes
post #1 of 15 (permalink) Old 04-28-2016, 04:02 PM Thread Starter
Default How can I make this post cap?
Hey guys. I'd like to make my own post caps and eventually mount some LED's in them. These will be going on 6X6 posts. I'd like them to look like this:
The bottom wrap around trim I will purchase, but I'd like to make the top cap piece. Any idea how to do this? The largest bit I have is a 3-1/2" for doing raised panel cabinets.
stlb5 is offline
post #2 of 15 (permalink) Old 04-28-2016, 06:30 PM
Hey, Stlb5; welcome!
Buy one, make a/some mould(s), cast the rest with fibreglass?
Just a thought.
billyjim and Gaffboat like this.
DaninVan is online now
post #3 of 15 (permalink) Old 04-28-2016, 06:45 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is online now
post #4 of 15 (permalink) Old 04-28-2016, 07:27 PM
CharleyL's Avatar
First Name: Charley
For doing just the top piece, I see a raised panel bit followed by a cove bit of just the right size. Careful setting up of the router table with each bit and a fixture to hold the piece perfectly square to the fence as you pass it through. It's going to take a few pieces of dimensioned scrap to get the settings right. Of course, a shaper could do it too, but with similar set up difficulties.
Cutting the stock the correct width and making two passes, then cutting into squares and making the other two passes would at least make part of the job a little safer. Several feather boards needed for this.
Charley
Central North Carolina
CharleyL is offline
post #5 of 15 (permalink) Old 04-28-2016, 07:27 PM
welcome to the forum oh nameless person...
panel bit...
Freud Tools | 3-1/2" (Dia.) Raised Panel Bit (Quadra-Cut)
round over or half round bit to match the profile......
post #6 of 15 (permalink) Old 04-28-2016, 08:10 PM
Assuming that you have a table saw - Cut the edges of the top surface on the table saw, blade height set to the intersection of the vertical and tapered surfaces. Using a high auxiliary fence, set the blade to the correct height/angle and move the fence until the corner of the blade intersects the edge of the first cut - this will give you the flat top and the bevel down to the edge. The final edge could be done on a router table using a round-over bit set deep to give a vertical edge - I'm assuming that the purchased molding is what's shown below that.
tomp913 is offline
post #7 of 15 (permalink) Old 04-28-2016, 08:43 PM Thread Starter
Thanks everyone, that's about what I was thinking, but with the round over bit, it seems like it would have to be upside down from the bits I have to use a table.
stlb5 is offline
post #8 of 15 (permalink) Old 04-28-2016, 09:46 PM
The round over bit would be mounted in the router table, with the bit projecting enough to give you the required step from the tapered surface and the OD of the bearing flush with the face of the fence - the fence would then limit the depth of cut into the part. You may have to take several passes to remove the amount of material needed.
tomp913 is offline
post #9 of 15 (permalink) Old 04-28-2016, 09:49 PM Thread Starter
I see what you're saying, but assuming I'm using a 2X, I'm not sure I can get the bit that high. I'll try and mock it up.
stlb5 is offline
post #10 of 15 (permalink) Old 04-28-2016, 11:24 PM
I would do like Tom says on the table saw. And the bottom edge on the router table first pass with the piece vertical and second pass with the piece laying flat on the table, that should give you a half round bull nose.
Then do the moldings on the router table too.
Herb Stoops is online now
BobCAD CAM User Feed Back aldepoalo CNC Routing 33 07-13-2015 02:27 AM
How to Make a router Template MT Stringer Jigs and Fixtures 8 04-22-2015 01:46 PM
The one post I never wanted to make xplorx4 Shop Safety 164 12-05-2012 06:48 AM
Porch Post Design Using Router Flint Hilltopper Show N' Tell 35 05-26-2012 10:59 AM
