How to create a strait edge for joining - Router Forums
 3Likes
post #1 of 16 (permalink) Old 05-04-2016, 10:38 AM Thread Starter
Everend's Avatar
First Name: Everend
Default How to create a strait edge for joining
I'm making two doors out of cedar 2x6 stacked horizontally. I stacked and dried the wood for several weeks and run each of board through the thickness planer. Now I'm trying to get straight edges so I set my router up as a jointer. It works for smoothing the edges but it's not straightening them. The split fence is offset by the thickness of a few fender washers. Boards range from 45"-52" the fence is 33" What am I doing wrong?
My first attempt was using a single feather board holding it to the fence. That gave it a good 90° edge but it's not straight down the length of the board.
Next thought was to add more feather boards so I made two more, but that still doesn't give me a strait board. Next step is to try to make a longer fence.
Name:	2016-05-03 15.03.41.jpg
Name:	2016-05-04 10.32.56.jpg
Everend is offline
post #2 of 16 (permalink) Old 05-04-2016, 10:44 AM Thread Starter
Everend's Avatar
First Name: Everend
After preparing all the boards I'll use the router to cut a tongue and groove in each and chamfer each board's before glueing them up. Once glued up I'll cut the door to width, chamfer the freshly cut end grain edges and sand down before finishing.
I gave the customer a bunch of sample cuttings of cedar with every finish I had in my shop, they choose linseed oil. Since then I've read that it's not a great option since sometimes it doesn't ever dry. I'm thinking about switching finishes to something that is sure to dry. Any suggestions?
Everend is offline
post #3 of 16 (permalink) Old 05-04-2016, 12:11 PM
Nickp's Avatar
First Name: Nick
What's happening is the radius of the bend in the board is greater than the length of the fence. If you're using the router to "straighten" the board you will need a longer fence...one that will keep the board in the proper registration longer as you pass the bit.
Maybe the table saw might be the better approach to straighten the board first and then clean it up with the router...?
Nick
Nickp is offline
post #4 of 16 (permalink) Old 05-04-2016, 12:51 PM
or....
Stick486 is offline
post #5 of 16 (permalink) Old 05-04-2016, 02:09 PM Thread Starter
Everend's Avatar
First Name: Everend
Thanks Nickp & Stick. based on your suggestions here is the solution. Rip a straight edge with circular saw, then cut the other edge parallel with the table saw.
Too bad I didn't ask this question before wasting 2 days getting the router table setup (building the new router fence, wiring up a switch on the table, making three feather boards, buying 2" strait bit, making two different styles of push blocks). Granted these were all things on my todo list anyway but I need to get paid and making things for my shop doesn't pay the bills directly.
Name:	2016-05-04 13.32.01.jpg
Name:	2016-05-04 14.00.27.jpg
Rogerdodge likes this.
Everend is offline
post #6 of 16 (permalink) Old 05-05-2016, 07:54 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Everend, this is an often occurrence...
On the table saw, place something BETWEEN your workpiece and your fence.
Said "sandwiched piece" should have toggle clamps to maintain snug between both sliding parts.
MAKE CERTAIN NOTHING BUT THE WORKPIECE IS GOING TO BE CUT!
Depending on your Router Table setup - this same idea can be applied there, as well!
OPG3
Tweak everything!
OPG3 is offline
post #7 of 16 (permalink) Old 05-05-2016, 08:55 AM
Country: Mexico
First Name: Joseph Anthony
Thumbs up
I like those feather boards, well made.
cocobolo1 likes this.
Cheers.
Joe
RÖENTGEEP is offline
post #8 of 16 (permalink) Old 05-05-2016, 09:05 AM Thread Starter
Everend's Avatar
First Name: Everend
I don't get it. Are you talking about a long sacrificial fence?
Everend is offline
post #9 of 16 (permalink) Old 05-05-2016, 09:11 AM Thread Starter
Everend's Avatar
First Name: Everend
Thanks, one problem I still have with them is the screw on the wing nut turns as I tighten the wingnut to force the splines of the oak out to lock the miter bar in place.
I got the idea of using a screw in a countersunk hole from the Bench Dog featherboard I have. On theirs the screw has a rib/spline on the cone portion of the head to keep it from spinning. I don't know how to add splines to the head of the screw. I thought of drilling a needle thin hole and putting a needle in there. Maybe epoxy a needle into the kerf of the flat head? Any ideas how to improve this design?
Everend is offline
post #10 of 16 (permalink) Old 05-05-2016, 09:18 AM
Country: Mexico
Lightbulb
Mmmmmmmm. I put a pair of tiny solder spots on the cone portion of the head in opposite position.
Cheers.
Joe
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 10:21 AM
Greater than japa62 Jigs and Fixtures 12 01-16-2013 12:03 AM
Freud Edge Guide Mystery Chappmann Jigs and Fixtures 4 12-26-2011 01:36 PM
Jig for Edge Drawer Pull Inlays Troy_Utah Jigs and Fixtures 9 01-30-2010 07:05 AM
finger joint bit for edge to edge atmartin23 Router Bits - Types and Usage 20 09-04-2009 01:51 PM
