slot cutter, adjusting depth of cut - Router Forums
 3Likes
post #1 of 14 (permalink) Old 05-09-2016, 04:03 PM Thread Starter
First Name: Tony
Default slot cutter, adjusting depth of cut
I have the Harbor Freight slot cutting set. Like most they have a 5/16th arbor and generate a 1/2" depth of cut. I'd like to make a 1/4" depth of cut.
Unfortunately according to the local bearing supply store, there isn't a 5/16" ID bearing with a 1/2" larger OD.
The QC on the HF cutter is upto their usual standards, on one the bearing slid on/off the shaft (ideal) but the end thread was badly stripped, on the other (that I ended up buying) the bearing is a tight press fit.
A loose fit would be better as I was thinking of just machining some rings on my lathe and pressing onto additional bearings so I could adjust the depth of cut. I was hoping to avoid having to buy additional arbors.
Not sure if there is a better way? I know CMT makes a nice kit where the depth is adjustable but it's over $100 and I'm only going to use this cutter very occasionally.
dorkshoei is offline
post #2 of 14 (permalink) Old 05-09-2016, 05:24 PM
or on almost every spline you do...
Freud Tools | 2" (Dia.) Stacked Slotting Set
post #3 of 14 (permalink) Old 05-09-2016, 06:34 PM
First Name: Earl
Look here, MLCS Slot Cutter Router Bits and Stackable Slot Cutter Set. Scroll down a bit to see the sizes available on that page, then search "bearing" if what you need is not listed. Also, 8mm ID may be what you're looking for instead of 5/16". Then there is always the Whiteside bearing kit, Buy Whiteside BB501 Bearing Kit with Wrench at Woodcraft.com (this vendor didn't list the ID, so you'll want to shop the internet or check Whiteside's web site). I've had good dealings with MLCS--but Whiteside is a top-notch manufacturer.
Everything is available somewhere--the only question is the cost.
earl
greenacres2 is offline
post #4 of 14 (permalink) Old 05-09-2016, 07:36 PM
Welcome to the forum Dorkshoei. You can get different bearings fairly cheap (from $4) but check out "rub collars" near the bottom of the page in this link.Bearings | Rub Collars | Router Bit Bearings | Shaper Rub Collars
Eagle isn't the only place they are available from but Eagle is as good as any place. I do hope you'll take a few minutes to update your profile with a name or nickname. I don't want to have to refer to you as Dorkshoei or the shortened version which would be Dork.
post #5 of 14 (permalink) Old 05-09-2016, 08:24 PM Thread Starter
First Name: Tony
Thanks for the mlcs link. The current bearing is 5/16 ID; 7/8 OD, so I need 5/16 ID; 1-3/8 OD to drop the DOC from 1/2" to 1/4". I see the #12113 bearing gets me that. A few other interesting sizes also.
Not sure I fancy spending $29 on 4 bearings. That said they seem to have a 6 piece #234 kit for $29.95
I wonder if they are made specially for MLCS or if the bearing supply store was just incorrect about nothing being available. Normally they have access to pretty much everything bearing.
post #6 of 14 (permalink) Old 05-09-2016, 08:26 PM Thread Starter
First Name: Tony
you can refer to me as DS. works for me, dork's fine too
post #7 of 14 (permalink) Old 05-09-2016, 08:33 PM
you realize that is the equivalent of opening the front door and laying out the welcome/have at it mat around here???
DaninVan and jj777746 like this.
post #8 of 14 (permalink) Old 05-09-2016, 08:47 PM Thread Starter
First Name: Tony
I know how to bite back
Seriously, I'll probably get that 6 Piece Accessory Bearing Kit #234 from MLCS, works out to just over $4.80 each. Of course I'll always pay less
post #9 of 14 (permalink) Old 05-09-2016, 10:05 PM
Honored Member
First Name: pat
Strip the bearing from the arbor, add some spacers and use the router table fence. Can be adjusted to any number, why not?
Quillman is offline
post #10 of 14 (permalink) Old 05-09-2016, 10:07 PM
hawkeye10's Avatar
First Name: Don
I buy a lot of things from MLCS. They aren't the best but good enough if you don't a bit day in and day out.
Don in Murfreesboro,Tn.
hawkeye10 is offline
Setting depth of cut accurately greyguru New Member Introductions 12 09-15-2014 03:47 PM
Biscuit cutter or slot cutter on router table Jerry Bowen Tools and Woodworking 7 09-14-2013 09:16 AM
Dovetail Depth of Cut Sherwood Portable Routing 10 11-19-2012 09:36 AM
Slot Cutter or Spline cutter kimbert General Routing 3 10-20-2005 06:26 PM
slot cutter jig knuttle Jigs and Fixtures 1 12-19-2004 07:04 AM
