Need help with my DW 618 router. - Router Forums
 4Likes
post #1 of 13 (permalink) Old 05-12-2016, 12:03 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Need help with my DW 618 router.
When I tighten a bit in the collect "1/2 or 1/4 inch shaft" then loosen it the nut will make about one turn then tighten up again. I then have to use the wrench to get it over the rough spot then it comes off with no problem. I have cleaned and recleaned then used some Flitz and worked the nut back and forth. I don't have the problem with no bit in the collect. I have used more than one brand of bits and set the shaft at different levels.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 13 (permalink) Old 05-12-2016, 12:35 PM
Nickp's Avatar
First Name: Nick
Yes, that is normal on most routers with tapered collets. That second tight spot is the collet nut pulling the taper away from the spindle...
Be careful of tightening the collet without a bit...it may damage the collet.
I'm sure others will chime in with a better/more technical answer...
del schisler likes this.
Nick
Nickp is offline
post #3 of 13 (permalink) Old 05-12-2016, 12:44 PM
N'awlins77's Avatar
First Name: Lee
What Nick said, it's normal!! And no, you do not want to tighten without a bit in the collet. AND, don't slide the bit against it's shoulder and tighten the nut. Slide the bit in all the way and then back it out a little. I use a 1/4" or 1/2" (I.D.) o-ring (depending on size of shank) to keep it spaced out.
N'awlins77 is offline
post #4 of 13 (permalink) Old 05-12-2016, 12:57 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Thanks guys!! It's always nice to hear a problem isn't a problem.
Great idea on the O- rings Lee.
N'awlins77 and bcfunburst like this.
post #5 of 13 (permalink) Old 05-12-2016, 02:35 PM
This is how self releasing collets work Don. First they are loosened and then the nut causes the collet to spread so the bit slips out easily.
post #6 of 13 (permalink) Old 05-12-2016, 02:44 PM
see if this helps...
Stick486 is offline
post #7 of 13 (permalink) Old 05-12-2016, 05:07 PM
Honored Member
First Name: pat
The manual should explain that in detail.
Quillman is offline
post #8 of 13 (permalink) Old 05-12-2016, 05:28 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Pat I can't believe you said that. I almost never read manuals.
Roy Drake likes this.
post #9 of 13 (permalink) Old 05-12-2016, 06:09 PM
Real men don't need manuals. They're just words.
HJ
Probably should have read some of them
honesttjohn is offline
post #10 of 13 (permalink) Old 05-12-2016, 06:48 PM
TwoSkies57's Avatar
I have a habit of getting a new tool and intentionally avoiding the manuals. I spend what I consider enough time to figure it out. For me this kinda helps fill that void between my ears on the new tool. Once I've figured it out or THINK I've figured it out, I go to the manual to check and see if I was right/wrong or missed something. IIRC I spent a couple days on my LS17 and the PC4216 before breaking down and getting out the manuals *LOL*... I've got a Seiko Chronograph that is a prized piece of jewerly I got 18 years ago, still havn't figured it out, but its a damn fine looking watch
Skipper the Penguin
TwoSkies57 is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
