Which dust collector unit would you buy? - Router Forums
 5Likes
post #1 of 24 (permalink) Old 05-18-2016, 09:29 AM Thread Starter
Default Which dust collector unit would you buy?
I keep thinking about redoing my dust collection and this post suggests some possibilities for building something to house it attached to the outside of the shop, something like an exterior housing for a water heater. With all the money I've spent trying to avoid buying a commercial unit, I could have bought a Jet and be done with it. I think for convenience sake, that it is really nice to have a clear plastic bag to hold the majority of the sawdust. I keep my jointer and planer in the garage, and they produce a lot of fluffy waste, so I could use two systems. That's about $700 bucks, but, I am really tired of all the sawdust and would like a better system.
The choices seem to be the Jet and the HF. The Jet is $365, the HF unit is on sale for $229. The HF has a somewhat higher hp rating. Any opinions about which you'd choose, and why?
Name:	J hf DUST COLLECTOR 230 BUCKS.jpg
DesertRatTom is online now
post #2 of 24 (permalink) Old 05-18-2016, 09:40 AM
kp91's Avatar
First Name: Doug
Tom,
If you are going to mount it outside of your shop, buy the biggest HF unit you can. The cheaper bags may make a little bit more of a mess, but it's outside. Put a 30 gallon trash can cyclone separator in line with it and you will never have to open the bottom bag again. (I exaggerate, but it is amazing how little makes it to the collector.)
I have a 1.5 horsepower grizzly with the separator lid and it handles the jointer and the planer just fine. I have to connect one tool at a time, but it's not that bad. If I had a larger unit I might be able to get away with some longer ducting runs.
Dont' forget your HF 20% off coupon.
My separator lid was a Shop Fox,(it looks like this one) http://www.grizzly.com/products/30-G...campaign=zPage
but they are everywhere http://www.woodcraft.com/product/143...clone-lid.aspx
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 24 (permalink) Old 05-18-2016, 09:57 AM
this one...
post #4 of 24 (permalink) Old 05-18-2016, 10:41 AM Thread Starter
@Stick486
I really like Powermatic stuff, but $600 per is a little over the top, especially if I get two, which is my preference. I plan to wheel the garage unit out onto the driveway to port dust outside. The unit for the shed will be housed on the back wall with a door and lots of air circulation through vents that will keep the rain off.
For the shop shed unit, I might forget about the bag and just build a 4-sided filter box with washable filters. By putting it outside, I gain enough space for a drill press.
I am leaning toward the HF at this moment, since it is on sale. Maybe one for the garage first to see how it does. $229 is awfully hard to beat.
post #5 of 24 (permalink) Old 05-18-2016, 10:49 AM Thread Starter
Originally Posted by kp91 View Post
Tom,
My separator lid was a Shop Fox,(it looks like this one) 30 Gallon Dust Collection 2 Stage Cyclone Separator | Grizzly Industrial
but they are everywhere Buy Trash Can Cyclone Lid at Woodcraft.com
The separator is the annoying part of my present setup because there's an astonishing dustcloud when I empty it. Since the HF unit has plastic bags for chips, changing bags should less messy.
I will be using a flex hose from tool to collector, so I won't have permanent ducts. I also recall reading something about extending the vanes in the HF blower to increase air flow, I'll try to find it again.
post #6 of 24 (permalink) Old 05-18-2016, 10:59 AM
MikeMa's Avatar
I have the HF, and it works well, especially for what it costs. I have 4 machines ducted to it, each with a blast gate. The Jet you showed is actually a much smaller unit that really is meant for direct single machine hookup.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #7 of 24 (permalink) Old 05-18-2016, 11:24 AM
johnnie_dr's Avatar
Hey DR-Tom
I have the 2HP Harbor Freight DC, with Wynn Filter and a Thein Baffle I made. I recently reconfigured the whole unit so that the motor/impeller was directly in-line with the inlet to the filter and bag section. Thus having a short-straight 6inch section of the of the same type of pipe.
I made the Thein baffle and put it on top of a of a 35 gallon poly-tub I bought through Amazon (was about 50 bucks). So I've upgrade the top bag with the Wyne filter and the bottom bag with the tub. Of course, my set-up is not portable, but you could do a few quick & easy modifications to still keep those add-on, on the HF cart. I bought my HF for $159. with the coupon and it works great.
If I could have afforded it , I would have gone with the Jet unit, or the better Powermatic (as Stick showed) or even better an Oneida Cyclone...but too expensive.
You can see my unit setup on my website, here: The Shop | RioDesign ? Creative WoodWorks
As you can see from the pics, I tie my Table saw, my router table, my miter saw into my main trunk line, plus I have drops to quick-connect to my planer and jointer. These are all controlled through blast gates and a remote start/stop switch.
Hope that helps...have fun
Johnnie
gjackson52 likes this.
johnnie_dr is offline
post #8 of 24 (permalink) Old 05-18-2016, 11:41 AM
RainMan 2.0's Avatar
I bought a general DC and it looks very simular to your top picture . It's 1.5 hp and 1250 cfm , and I'm a little disappointed with its power . Wish I had gone with one rated more than this , and it's located not to far from my table saw . It does ok , if your good with just ok
Ok ,I never insulate
RainMan 2.0 is online now
post #9 of 24 (permalink) Old 05-18-2016, 02:06 PM Thread Starter
I found with my shop setup that once I ported the exhaust to the outside instead of using a bag, the air flow increased dramatically.
The motor is rated 2 hp and 20 amps, which I have available in the shop, but not the garage at the moment. May have to have an electrician drop in a 20 amp circuit just for it. However, I think someone on the forum said that 1.75 hp is the max for a 110v motor.
As I mentioned above, I saw a fix to enlarge the impeller and thus the air flow, but haven't located it again yet. I will be hooking it up to one machine at a time. Thanks for the feedback.
post #10 of 24 (permalink) Old 05-18-2016, 05:00 PM
Tom; I also ran into an article on that...same one?
The issue was if I recall correctly, that increasing the impeller diameter increases the load on the motor. ie the motor has to work harder causing more of an electrical load.
The article detailed measuring amperage before and after the changeover, and knowing in advance what the motor would tolerate over a period of time. If the motor fails than any cost saving is moot.
Removing downstream restrictions seemed to be a better bet in the scheme of things. Starting with the baffle on the output side.
DaninVan is online now
Improved Lighting For My Scroll Saw CharleyL Wood Scrolling 32 02-06-2020 02:34 PM
Dust collection - Do something about it... DesertRatTom Woodshop Dust Control 34 07-16-2019 10:23 PM
Miscellaneous Dust Collection Stuff MT Stringer Show N' Tell 9 12-01-2014 11:54 AM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 04:01 AM
Dust Deputy Cyclone Dejure Tool Reviews 3 06-16-2014 08:46 PM
