CNC router vs Laser Cutter/Engraver - Router Forums
post #1 of 1 (permalink) Old 05-19-2016, 09:44 PM Thread Starter
Default CNC router vs Laser Cutter/Engraver
Hi,
This is my first post here. As all we know laser cutters/engravers improved a lot during the recent years. However, are the current laser cutters able to mill small (80mm x 20mm, height: 3mm) acrylic pieces (as a router do) with the same accuracy in the Z-Axis? AFAIK, laser cutters may have a better X and Y resolution but Z resolution is just fine for decorative engraving but not so much for pieces production. Am I right?
Thank you in advance for your replies.
lpgasparotto is offline
a full size drawing saved as a vector to machine in plasma, laser or cnc router woodman12 CNC Routing 4 01-25-2016 07:37 AM
Purchasing plans (G-Code) for my CNC Router Dukie94 CNC Routing 5 10-27-2015 07:21 PM
Need advice CNC End mills Vs. router bits SubmarineGuy CNC Routing 8 11-17-2014 07:59 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
CNC router, laser or NOT Brad Swenson CNC Routing 10 07-28-2011 01:54 AM
