Machining very thin acrylic pieces - Router Forums
 5Likes
post #1 of 18 (permalink) Old 05-20-2016, 10:34 PM Thread Starter
Default Machining very thin acrylic pieces
Hi,
I need to machine pieces like the one in the picture in acrylic (PMMA, Plexiglass).
In you eperience, which would be the best machining strategy for this piece? Would this piece require a special featured router or would it be possible to make it with common routers? Would it be better to use a big router or a desktop router?
How could I avoid...
... the 0.1mm section gets break during routing process (tool, speed, RPM,...)?
... the piece gets warp after routing?
Thank you very much in advance.
lpgasparotto is offline
post #2 of 18 (permalink) Old 05-20-2016, 10:43 PM
welcome to the forums nameless person...
I believe a CNC machine w/ a vacuum clamp would be the overall best way...
I believe that if you used a table saw (TS) you would have to deal w/ ''chatter'' and w/ the nick sensitivity of acrylic you will have to deal with fracturing/chipping...
post #3 of 18 (permalink) Old 05-20-2016, 11:26 PM
RainMan 2.0's Avatar
I tried cutting 12mm plexi with my 80 watt laser and was unimpressed . 6mm it did a fantastic job though .
I have been cutting 12mm lexan on my tablesaw and had great results , but not sure about plexi .
I finish the lexan off with differant grits of sand paper . Starting with 120 and ending with 400 . That's if you want it clear edges . Also flame torched the edges instead of sanding if I felt lazy , but you have to be very careful not to burn the plexi .
If you merely doing squares and rectangles I don't see why a tablesaw won't work . The problem comes when you want curves , as now your cutting out the shape with a jig saw and finishing off with a router table using an mdf template attached to the plexi .
I found I had to leave very little material past the template to remove or the router bit would grab it and became a lethal projectile . Not to mention it bent the bit
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 18 (permalink) Old 05-20-2016, 11:31 PM
use a TCG negative rake blade on your TS and improve your cuts...
Freud Tools | 10" Plastic Blade
JohnnyB60 and RainMan 2.0 like this.
post #5 of 18 (permalink) Old 05-21-2016, 05:08 AM
vchiarelli's Avatar
First Name: Vince
Aside from the other issues already mentioned, your piece is approximately 1/2 inch by 3 inches and tapers down to almost nothing - that's a pretty small piece to manipulate with a router - hand held or table mounted.
Perhaps if you told us what the intended purpose of the piece is, you might get some other suggestions on material or tools to use.
RainMan 2.0 likes this.
vchiarelli is offline
post #6 of 18 (permalink) Old 05-21-2016, 08:42 AM
Honored Member
First Name: pat
Work is radiused, unflatten-able without breaking?
A hollow tube? You just want to cut a section out of the top?
Or is the whole length the work?
I cut Acrylic; it's what I do.
Depending on the dimensionality of the work, there are few surprises. Band saw first, then anti-climb cut to template.
1.5hp is plenty of power; I would not use a trimmer.
Full speed (18-25kRPM) at ~20'/min with a new cutter (2 flute carbide, 1/2" diameter or greater) will not weld, chatter of crack the work. Caveat: Test on scrap.
Quillman is offline
post #7 of 18 (permalink) Old 05-21-2016, 09:43 AM
Welcome to the forum Ip. If I'm reading your drawing correctly you want to mill a piece of plastic that is 3.2mm (1/8") on the the thick end down to 0.1mm (1/254") on the thin end and with a convex profile across the width. Since the drawing shows that the end is only slightly rounded without being tapered across the width as the piece gets thinner then by default the concave curve of the piece must progressively flatten out as the piece gets thinner. That qualifies this as a very complex shape, one that will be extremely hard to produce without a CNC router. You will pretty much require computing power and computer control to get this one right and done easily in my opinion.
post #8 of 18 (permalink) Old 05-21-2016, 10:36 AM
Contributor of the Month
Dejure's Avatar
First Name: Kelly
Cutting acyrilic, plexi or laminate are all about the same. In fact, it is much like cutting 1/8" paneling.
As stick pointed out, dealing with chatter is critical to quality cuts. When cutting thin stock on a table saw, keep the back as high as you need to, to insure the part hitting the blade is pressed against the table. Sometimes, this may mean holding the back as much as three feet in the air. You may have to twist the stock at the same time, so the right back right is even higher than the left, to put more pressure on the left front.
If you did a couple sheets of wood paneling, this would, quickly, become second nature and quite comfortable to do. The material slides right through, like butter.
I've had excellent results using my sixty and eight tooth blades for laminate and plexi or acyrlic, but I now use the recommended blade, since they double as aluminum cutting blades. However, I did not buy a ten inch blade, since I've never cut stock more than an inch thick. As such, a seven inch blade may be all you need, and it will be much cheaper than a ten inch.
JohnnyB60 likes this.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #9 of 18 (permalink) Old 05-21-2016, 12:28 PM
What TPI band saw blade do you use,Pat?
Herb Stoops is online now
post #10 of 18 (permalink) Old 05-21-2016, 01:01 PM
Sorry I misunderstood the question and didn't realize we were cutting a thin curved piece of plexi .
I have no idea how I'd attempt that , other than building a mold and pouring that stuff that turns hard and is transparent
Tip for sanding very small pieces Gaffboat Tools and Woodworking 10 11-04-2014 04:26 AM
How to cut slots in 2 pieces that are not straight on outsides. Midnight Shadow General Routing 4 07-26-2010 11:04 AM
Routing small pieces of timber colbra General Routing 11 07-01-2009 06:51 AM
Round over on thin curved pieces Ken Massingale Table-mounted Routing 8 09-20-2004 05:36 AM
