Finally, first frame finished! - Router Forums
 30Likes
post #1 of 20 (permalink) Old 05-30-2016, 09:11 PM Thread Starter
Default Finally, first frame finished!
OK, finally got a frame finished I'm willing to show. My wife paints and frames cost an arm and a leg, and unframed paintings are pretty plain potatoes. Making a frame is exacting. 45 derees had better be exact or you have scrap wood. So my wife gave me a present, a Grizzly miter trimmer. Perhaps the sharpest tool I have ever had a small accident with.
BTW, this would be a $200 frame at the very least. But I have had to buy some special tools to be able to do this. First and foremost, the Girz miter trimmer, shown here in action, minus the blood. You precut the end to as near 45 degrees and about a 16th oversize. The trimmer shaves off a thin piece at an exact 45. It is a miracle after fussing with saws for several weeks.
Custom frames must be made to fit the canvas, so the inside edge requires a 3/8 ths rabbit, so the width of the frame is based on the correct width of the rabbit. Makes more sense when you actually do it. Clamps for glue up were small spring loaded clip. I didn't manage to get all the squeeze out, so had to do more sanding to get down to wood for the stain. I'll be more careful about glue removal in the future.
OK, next step was cutting 1/8th splines into the corners and gluing that up, the sawing off the ends with a Japanese pull saw.
OK, the picture of the painting. The frame is pine, finished with two coats of Red Mahogany penetrating stain and two coats of wipe on poly. The wood is actually just pine molding. I had to add some half inch pine to the back of it to give room for the rabbit. That really messed things up because I glued it on before cutting and assembling the frame. So, the face of the frame would NOT line up perfectly. Darn. The solution? Sand, sand, sand and sand some more to make it line up in the corners. Got down to 320 grit, put a stain pre coat to even it out, then sanded a little more with 400 grit, to remove the fuzzies, then a final coat of stain and a rubdown with an old T shirt to smooth out the finish. Then a couple of coats of wipe on poly.
Now, I know this is nothing new for the old farts here, but I'm posting this for others like me, who are intimidated by precision and finishing.
Frames loom as a big thing in my life given my wife's increasing art skills. So I bought a few specialty items, the best of which is in the third picture, which inserts the retainers into the frame. Nifty item but the thing bites is you grip it too hard. Oh well, more band aids.
Hope someone learns from my mistakes. I'll post some more over time.
Name:	2016-05-30 17.58.47.jpg
Name:	2016-05-30 18.43.16.jpg
Name:	2016-05-30 18.39.39.jpg
post #2 of 20 (permalink) Old 05-30-2016, 09:23 PM
that came out well done...
DesertRatTom likes this.
post #3 of 20 (permalink) Old 05-30-2016, 10:04 PM
Beautiful job Tom. I realized the the same as you when my wife needed some frames for some prints she bought. Ready made was $25 per foot and when I looked them I realized there were just coves and beads. Takes a while to recreate them but very satisfying and lots cheaper.
post #4 of 20 (permalink) Old 05-31-2016, 07:21 AM
First Name: Richard
Nice frame. Understand the cost of buying frames. When we return from vacations we always have pictures of scenery we want to frame and hang in the house. Big pictures like 16x20 and 20 x30. I started making them several years ago due to the high cost of buying them. We have some nice pictures and they keep the memories fresh.
Shop guy is offline
post #5 of 20 (permalink) Old 05-31-2016, 07:28 AM
vchiarelli's Avatar
First Name: Vince
Tom
That frame looks very professional - nice job
vchiarelli is offline
post #6 of 20 (permalink) Old 05-31-2016, 07:42 AM
hawkeye10's Avatar
First Name: Don
I like that frame Tom. Your wife will turn you into a full time framer.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 20 (permalink) Old 05-31-2016, 09:30 AM Thread Starter
Originally Posted by hawkeye10 View Post
...Your wife will turn you into a full time framer.
@hawkeye
LOL, I have already committed to that. Got past the don't know anything about finishing to a method that will work well, so now there are another 20-30 more that need frames PDQ. She has said something about making frames and she is connected to the art community.
post #8 of 20 (permalink) Old 05-31-2016, 10:09 AM
schnewj's Avatar
Guess we now know why frames are so expensive! Lots of work and tools to get there.
Good job, Tom.
DesertRatTom and Herb Stoops like this.
schnewj is offline
post #9 of 20 (permalink) Old 05-31-2016, 10:32 AM Thread Starter
I noticed during the learning process that most framing material is pre finished. I think that's what I'll try next. I do like the precision of frame making, but boy, is the finishing messy!
post #10 of 20 (permalink) Old 05-31-2016, 10:56 AM
Really nice job Tom. I know what you mean about the work & the mess, I frame pictures for a living. We used to have a brick & mortar store, but the rents drove us out of business. The people we deal with now know what they want and what they will pay for it.
Your wife looks like a very accomplished artist.
jj777746 likes this.
Potowner1 is offline
Finally finished jd99 Show N' Tell 2 06-18-2012 11:02 AM
Finally Finished The Coon and Hounddog Scene.... challagan Corey's Wooden Stuff 12 12-20-2011 04:11 PM
Finally Finished jd99 Show N' Tell 7 12-31-2010 05:57 AM
I finally finished my "Norm" router station!!! rprice54 Show N' Tell 14 10-22-2009 10:45 AM
Finally finished huge outdoor sign. BlackBelt Sign Making 10 12-26-2008 06:08 AM
