Race Track Help - Router Forums
 1Likes
  • 1 Post By Mike
post #1 of 7 (permalink) Old 06-04-2016, 08:57 PM Thread Starter
First Name: Ron
Default Race Track Help
I have been asked by a church group to build something like the tracks in the pix below. After shaping the plywood sides, I don't know if one would route a groove for the plywood track surface to slip into. I would assume one would use 1/8 in plywood for the track surface since that would flex a bit, but I don't know how to attach the two sides of each of the tracks and to make sure the tracks are strong. Anyone do something like this or know of some plans that I could adapt. Each track is supposed to be about eight feet long and about five inches wide. Any help would be appreciated.
rweerstra is offline
post #2 of 7 (permalink) Old 06-04-2016, 10:31 PM
That's similar in principle to the Cub Car tracks that the scouts race their cars on. Maybe they have some advice for you.
If you used 1 x lumber to make the shapes that the plywood has to conform to then brad mnails should hold them down. Grooves cut into the sides of the uprights would also work if you made templates to follow so that both sides would be identical. I wouldn't woorry too much about strength over a distance of only 5" and with so little weight put on the track. Those little cars only weigh ounces.
post #3 of 7 (permalink) Old 06-04-2016, 11:17 PM
Ron, I don't think this is as difficult as it seems. Using double sided carpet tape fasten two 1" x 10" x 8' boards together. Layout your shape and cut it with a bandsaw or jig saw. Sand the edge smooth. Separate and cut a rabbit 3/8" deep by 1/2" wide mirror image on the two boards. This will leave you a 1/4" wide "retaining wall" with 1/2" wide support for the plywood. Cut your 1/8" ply to width and fasten down with contact adhesive. This gives you one lane. Use the other 1 x 10 pieces you cut off; flip them over and repeat the process to get the second lane. Repeat it all for the next two lanes.
paduke likes this.
post #4 of 7 (permalink) Old 06-05-2016, 06:33 AM Thread Starter
First Name: Ron
Thanks guys. You make it sound simple enough. That's what happens when you over think a challenge.
post #5 of 7 (permalink) Old 06-05-2016, 07:00 AM
TwoSkies57's Avatar
take a look at using FRP for the track surface.
Shop Panolam 8-ft Fiberglass Reinforced Wall Panel at Lowes.com
easy to cut w TS or razor knife, at 5-6" wide, VERY flexible, put the textured surface down, smooth side up, light weight, 1 sheet should yield 6-8 tracks,
Skipper the Penguin
TwoSkies57 is offline
post #6 of 7 (permalink) Old 06-05-2016, 03:01 PM
OH! When I saw this thread I thought it was a new system to pick the winners at the track. LOL
Herb Stoops is online now
post #7 of 7 (permalink) Old 06-05-2016, 05:09 PM
Could the surface be a piece of Formica? It looks like it has a shine vs plywood?
UlrichJ is offline
For Sale: Eagle-America Wooden Train & Track Kit Ray Newman Woodworking Classifieds 0 10-04-2015 03:42 PM
Anyone use a Festool track saw ? RainMan 2.0 Tools and Woodworking 39 07-03-2015 03:07 AM
Router miter slot vs track jetjocky New Member Introductions 10 01-24-2015 08:14 PM
Makita Track Saw and Dewalt DWS5031 Router Adapter gvales Tools and Woodworking 1 11-16-2012 07:55 PM
A "closed-in" mitre track? matt1710 Table-mounted Routing 8 05-22-2011 06:27 AM
