Zero clearance insert for table saw - Router Forums
 12Likes
post #1 of 18 (permalink) Old 06-07-2016, 05:05 PM Thread Starter
Keith C's Avatar
First Name: Keith
Default Zero clearance insert for table saw
What wood do you guys use to make a zero clearance insert? I'm guessing the harder the wood the longer it will last? I have some red oak that is sitting around, but is pine good enough?
Keith
Takoma Park, MD
Keith C is offline
post #2 of 18 (permalink) Old 06-07-2016, 05:12 PM
baltic birch...
Stick486 is offline
post #3 of 18 (permalink) Old 06-07-2016, 06:07 PM
hawkeye10's Avatar
First Name: Don
As Stick said Baltic Birch is very good as it is more stable. Also if you got oak on hand use it. I would stay away from pine.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 18 (permalink) Old 06-07-2016, 06:12 PM
Scraps of ordinary Birch plywood. I just replace it when it gets beat up a bit.
Make a bunch at the same time...just don't cut the blade slot until you actually need it.
If you were a a bit obsessive you could shellac the top face. Frankly I couldn't be bothered.
DaninVan is offline
post #5 of 18 (permalink) Old 06-07-2016, 07:53 PM
I use any 1/4",or 1/2" plywood that I have laying around. Even have used tempered masonite, it works too.
Herb Stoops is online now
post #6 of 18 (permalink) Old 06-07-2016, 08:53 PM
BrianS's Avatar
First Name: Brian
I've used cheap, construction grade 1/2" plywood, as well as 1/2" mdf. The Baltic birch plywood is probably the best material, but if you don't have it, the other works just fine. I also found that putting a coating of paste wax on the insert helped the wood move across it.
When I made mine, the insert was a bit sloppy fitting. I wrapped tape around the outside of the template, until it fit tighter.
Shop guy and Herb Stoops like this.
Brian
(Origin uncertain)
BrianS is offline
post #7 of 18 (permalink) Old 06-07-2016, 09:21 PM
I bought a large plastic cutting board about 3/8ths thick for my inserts. Get three per sheet. Hold up nicely, wood slides on it without friction, and it is easy to install set screws to level the plate. Stick suggested that material. Otherwise, I'd use cutoffs of half inch Baltic Birch. You can order a 20x30 piece at Amazon, enough to make a nice batch. The most important thing is that the material is FLAT, so check with a straightedge. Forget using pine.
post #8 of 18 (permalink) Old 06-08-2016, 12:54 AM
I just used mdf. It will also drill and tap for leveling screws. From the replies it's obvious that it isn't that important so use whatever you have handy.
post #9 of 18 (permalink) Old 06-08-2016, 01:59 AM
good source for those cutting boards is the Dollar Store (or similar)...
cheap...
thomas1389 likes this.
Stick486 is offline
post #10 of 18 (permalink) Old 06-08-2016, 05:36 AM
cheap...
@Stick486 I tried there, but my Laguna has a LONG insert and they didn't have stock big enough, so I bought a really large one at Target, from which I got three. One other thing, I have a number of blades so I have labeled the blades that work with a particular insert. I have come to appreciate the virtues of a full kerf blade, and I got one of those double blades with the offset teeth that can cut 1/4 and 3/8ths, which needs two inserts. For a dado stack, I have been using Baltic Birch inserts, since I had several I made at once.
And yes, it is a good idea to make a bunch of them at the same time. Someone suggested using the original insert as a pattern, but the Laguna insert is split at the back and not suitable for use as a pattern. Somewhere I saw a video where the guy simply cut a strip to the width of the slot, marked a centerline, then used a compas set for half thw width of the piece, drew a half circle on each end to match the exact length. Cut it out with a band saw and used it as a template to make usable inserts. One precision task makes production much easier after that.
My TS blade rests just about 3/16ths below the top, so I have to rout out a slot for the blade to fit in before I raise it through.
Making A Zero Clearance Table Saw Insert Gaia Project Plans and How To 4 04-10-2016 10:46 AM
Crosscut Sled Zero Clearance Insert FreeTime Tools and Woodworking 15 06-28-2015 12:30 PM
Zero Clearance Insert bobswoodshop Tools and Woodworking 3 08-31-2011 07:08 PM
Bench Dog Pro Plate and Zero Clearance Insert problem matt1710 Table-mounted Routing 24 07-17-2011 07:37 AM
guide to making zero clearance inserts ZCI blurry Tools and Woodworking 12 03-01-2009 11:13 PM
