220V Foot switch - Router Forums
 3Likes
post #1 of 30 (permalink) Old 06-07-2016, 05:09 PM Thread Starter
Keith C's Avatar
First Name: Keith
Default 220V Foot switch
I was thinking to get a DC and realized I had a 110V foot switch, but some DCs can, and probably should, be run on 220V. In looking for switches, I saw most were only momentary. I like the ones that stay on, SPST or the like. I looked on grizzly and amazon, but most on amazon are for sewing machines it seems.
Keith
Takoma Park, MD
Keith C is offline
post #2 of 30 (permalink) Old 06-07-2016, 05:11 PM
use a 4 pole relay...
post #3 of 30 (permalink) Old 06-07-2016, 05:14 PM Thread Starter
Keith C's Avatar
First Name: Keith
Default Foot switch
Oh, and I mean at a reasonable price. I see some for $70-80, but that seems pretty expensive for a switch.
Keith
Takoma Park, MD
Keith C is offline
post #4 of 30 (permalink) Old 06-07-2016, 06:01 PM
hawkeye10's Avatar
First Name: Don
Keith my shop is small so I don't mind taking a step or two and turn it on. Every machine have is on wheels and I roll them to my DC when needed. Your situation may be different. Also 220 volt switches will cost more.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 30 (permalink) Old 06-08-2016, 12:35 AM
On any 220v circuit you only have to switch one wire. Each hot lead wire acts as the neutral for the other so if you interrupt one then there is no circuit. Most of the cables for power tools only have the two hot leads and a bare ground. You only need the third conductor (neutral i.e.) if you need to also run some 120 volt functions like the clock and lights on an electric stove. I run my air compressor by switching just one wire through the pressure switch.
Just as an after thought, I also hooked up my 220v DC that way. I wanted to be able to turn it on from either end of my shop so I used a pair of 3 way light switches to turn it off and on, only switching one of the two hot leads.
post #6 of 30 (permalink) Old 06-08-2016, 07:57 AM
Just as an FYI, I believe the various electrical codes require that both legs of a 220 (actually 240 today) volt device be switched to avoid having a hot, un-grounded wire beyond the switch when it is in the "off" position. Often violated but does create an unsafe condition.
senebraskaee is offline
post #7 of 30 (permalink) Old 06-08-2016, 09:00 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
https://www.amazon.com/Remote-Contro...=1&*entries*=0
Plug your DC into one, and carry the remote with you.
easy peasy lemon squeezy.
sunnybob is offline
post #8 of 30 (permalink) Old 06-08-2016, 11:04 AM
MikeMa's Avatar
I wouldn't use those. They are designed for a single light, so the amp rating for them are going to be very low. For a DC that runs on 110, you are going to be drawing 15-20 amps. For DCs I strongly recommend either use the switch built-in on the unit, or use a remote switch (wired or wireless) that is made for the amp draw of your DC.
This is not an area where you want to go cheap on.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #9 of 30 (permalink) Old 06-08-2016, 11:17 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
from the amazon blurb....
The Remote Controlled Switch Sockets are ideal for the remote operation of many electrical devices including lamps appliances tools and more
But I am not familiar with USA 110 volts systems, so possibly this particular item might not be suitable, but a remote switching socket is the easiest way to solve the problem.
sunnybob is offline
post #10 of 30 (permalink) Old 06-08-2016, 01:29 PM Thread Starter
Keith C's Avatar
First Name: Keith
I say that is bogus. In either case you have either 1 open circuit or 2 open circuits. Neither is more safe than the other, if I understand you correctly. If you only interrupt one wire, if that is possible need to look into it, you can't do anything to be more safe.
Keith
Takoma Park, MD
Keith C is offline
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Foot Switch = Convienants and Safety Marco Shop Safety 7 12-29-2013 11:24 AM
router foot switch mrmistake General Routing 11 11-18-2013 01:39 PM
Deadmans foot switch oldrusty General Routing 8 02-13-2012 05:55 AM
Foot switch oldrusty General Routing 14 02-11-2012 11:48 AM
