Plunge bits?? - Router Forums
 12Likes
  • 2 Post By Stick486
  • 6 Post By harrysin
  • 1 Post By FreeTime
  • 3 Post By FreeTime
post #1 of 10 (permalink) Old 06-09-2016, 05:21 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Plunge bits??
Using a plunge bit in a router table is it safe to let the wood down on the bit. Of coarse you would need to use the fence. I am talking about bits that are larger than 1/2".
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 10 (permalink) Old 06-09-2016, 05:50 AM
Tommy Law's Avatar
First Name: Tommy
Send a message via MSN to Tommy Law Send a message via Yahoo to Tommy Law
I would pre drill a good starting hole .
Tommy Baltimore
"To alcohol...The cause of and answer to most of life's problems!" H. Simpson
Tommy Law is offline
post #3 of 10 (permalink) Old 06-09-2016, 05:56 AM
stop block the end so it doesn't kick back and feather board it to the fence so it it doesn't separate from the fence...
can you raise the bit into the work and add a hold doen feather board???
are you slot cutting???
better to use a plunge router w/ a clamp on fence and take take the router to the work....
harrysin and JFPNCM like this.
Stick486 is offline
post #4 of 10 (permalink) Old 06-09-2016, 07:15 AM Thread Starter
hawkeye10's Avatar
First Name: Don
I was slot cutting yesterday with a 1/4" carbide bit. I lowered a piece of 1 1/4" wide by 8" long wood on the bit but I made the slot in three passes. I have no plans to make a larger slot but you can never tell. I am just asking the question so I will know the answer in case I need to.
post #5 of 10 (permalink) Old 06-09-2016, 08:19 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Irrespective of the bit size, holes and slots are produced safer using a hand held plunge router.
Harry
harrysin is offline
post #6 of 10 (permalink) Old 06-09-2016, 09:12 AM
Yes Don this is a commonly used method taught on the Router Workshop, Woodsmith and other woodworking shows. I use this method all the time. Putting painters tape on your fence and marking your start stop positions on it makes for high visibility and easy clean up.
Name:	US Ski jig 006.JPG
Name:	US Ski jig 007.JPG
Name:	US Ski jig 008.JPG
post #7 of 10 (permalink) Old 06-09-2016, 10:42 AM
I prefer to do like Harry does and use the plunge router on the job. That puts your hands in the safest place possible, i.e. nowhere near the bit. Lots do slotting on the table but there is a risk that the piece can get away from you and since you are holding on tightly if it does get start to get away there is a split second until your brain tells you to let go and your hand is being pulled along with the piece. The problem is that you only contact one corner of the bit first. If you ever have tried drilling with a large Forstner bit and you started at an angle then you know what happens.
If you go ahead and do the slotting on a table then use stop blocks to eliminate any motion in that direction leaving only motion away from the fence as a possibility and be aware of what can go wrong so that if you do start to lose control that your reflexes will be prepared to let go faster.
post #8 of 10 (permalink) Old 06-09-2016, 02:12 PM
First Name: Mark
My vote is with the hand held approach. I had a near miss once - don't care to repeat it (still trying to not learn the hard way)
I made a template out of 1/2" BB that I use actually quite a bit, anytime I need a "slot like" cut. Just a simple sheet 1'x3' (whatever) with a 1" slot cut in it to guide a 1" bushing and whatever bit I want to use. I made 2 centering keys for it (fits into the slot, with centerlines to match for setup.)
xylos likes this.
FreeTime is offline
post #9 of 10 (permalink) Old 06-09-2016, 03:00 PM
Why don't you take a picture and post it for us? If you need help with how to do it just ask and I'll walk you through it.
post #10 of 10 (permalink) Old 06-14-2016, 05:32 PM
First Name: Mark
Default Slotting Template
Sorry it took so long - shop was a mess. Anyway I generally use double sided tape from template to part, align the template using the key to the slot CL on both ends and clamp the whole thing down. I only had to fiddle with getting this slot straight.
A 1" guide bushing on a plunge router enables most slot configurations I have needed. Its an easier setup than a dado jig. (First photo - I zip tie the keys to the template for safe keeping)
FreeTime is offline
Router bit testing Mike Router Bits - Types and Usage 21 12-17-2014 09:42 AM
Auger Bits Mortising In Drill Press Gaia Tools and Woodworking 11 07-31-2012 11:46 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
Quick tip kp91 General Routing 23 09-24-2004 04:26 PM
