Makita 3612BR question - Router Forums
 2Likes
  • 1 Post By Cherryville Chuck
  • 1 Post By Mike
post #1 of 4 (permalink) Old 06-09-2016, 02:35 PM Thread Starter
First Name: Ed
Default Makita 3612BR question
Hi,
A friend gave me an old Makita 3612 BR router with a bit stuck into it. I can loosen the collet nut about one revolution but that's the end of it. I can't get the bit out and I am wondering whether the collet nut is supposed to come of completely or not? Can someone give me a hint?
Thanks,
Ed
router king is offline
post #2 of 4 (permalink) Old 06-09-2016, 02:52 PM
Welcome to the forum Ed. Many router collet nuts will turn freely when loosened and then tighten up again. If you continue to loosen the nut with the wrench it will start to turn freely again and the bit should be removable then. If it isn't you can try tapping the bit downward or sideways but be careful not to hit a cutting edge. Carbide is brittle and doesn't take impacts well. The 3612 was a good router and was used in many industrial shops.
Mike likes this.
post #3 of 4 (permalink) Old 06-09-2016, 03:15 PM Thread Starter
First Name: Ed
Worked like a charm, thanks a lot for the quick response.
post #4 of 4 (permalink) Old 06-09-2016, 04:51 PM
Glad you are up and routing again Ed.
gjackson52 likes this.
Questions about replacing bearings in a Makita 3612BR Grub General Routing 8 12-22-2014 07:03 PM
Collets for my Makita 3612BR Marcel M Router Bits - Types and Usage 10 06-17-2012 08:29 PM
