Problems with Bosch 1617EVS Plunge base - Router Forums
 2Likes
  • 1 Post By DesertRatTom
post #1 of 9 (permalink) Old 06-11-2016, 09:45 PM Thread Starter
Red face Problems with Bosch 1617EVS Plunge base
I purchased a barely used 1617EVS package that has the regular base the Plunge base and an additional base which I assume is for the router table, which I also have. I was trying to setup the Plunge base with the edge guide and I found out I am missing some parts.
I got a good deal so having to get some parts is not a huge issue. When I was seeing if the plunge worked properly I noticed that the plunge was hard to push down. I have a 3.25 Triton router and that goes down easy.
Does anyone know if there is some lubrication that needs to happen on the two shafts that take the plunge down. The locking lever is operating correctly but it just seems the shafts need something. The owners manual does not mention anything about lubricating that moving part.
Marty
Minnesota Marty is offline
post #2 of 9 (permalink) Old 06-11-2016, 10:03 PM
bad news is that if the router was dropped and things could be out of alignment...
better news is that the columns need cleaning and dry lubed..
if the base has been treated to WD-40 this wasn't a good thing... VOE...
also... call Bosch CS...
just in case...
Stick486 is offline
post #3 of 9 (permalink) Old 06-12-2016, 06:12 AM
What Stick said.....
Sydney, Australia
jw2170 is online now
post #4 of 9 (permalink) Old 06-12-2016, 07:58 AM Thread Starter
Thanks guys for the replies. This router was barely used. I doubt if the plunge base was ever on the router. So, I am going to try a good cleaning first. Sometimes the residue from manufacturing is just hardened and sticks. I don't think it was dropped.
When you mention a dry lubricant, I think of graphite like I use in a lock to loosen things up? Or what?
Marty
post #5 of 9 (permalink) Old 06-12-2016, 08:11 AM
lord no on the graphite...
you'll regret that one... VOE...
I like TriFlow... a lot...
Triflow - Tri-Flow Pin Point Lubricator
Stick486 is offline
post #6 of 9 (permalink) Old 06-12-2016, 08:22 AM Thread Starter
Got it. Glad I asked.
post #7 of 9 (permalink) Old 06-12-2016, 10:19 AM
Thanks, useful questions and answers. Have not yet used my plunge base and I think I'll get some of the tri flow.
billyjim likes this.
post #8 of 9 (permalink) Old 06-12-2016, 10:30 AM
@Stick486
Is Tri-Flow the lubricant you use for table saw parts? Seems there was a string on dry lubricant for table saws awhile ago. I think I'm overdue.
post #9 of 9 (permalink) Old 06-12-2016, 06:20 PM
Originally Posted by DesertRatTom View Post
@Stick486
yes.....
Stick486 is offline
Bosch pr10e plunge base Semipro General Routing 3 04-19-2014 08:24 AM
Sold: Bosch Plunge Base RA1166 tdobrynski Woodworking Classifieds 3 11-05-2013 03:49 PM
Bosch Router Plunge Base RA1166 CGL General Routing 2 10-03-2013 08:28 PM
bosch colt plunge base meddoc General Routing 7 07-24-2012 05:33 PM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
