Seeking routing advice - Router Forums
 13Likes
post #1 of 25 (permalink) Old 06-19-2016, 02:25 PM Thread Starter
First Name: Ed
Default Seeking routing advice
Hi,
I'm the proud new owner of an old Makita 3612BR router and I would like to start my very first small project.
Here's the situation: I have an 8x6.5" piece of over 100 year old walnut board, about 1" thick. The corners seem to be 90 degrees but one of the 8" sides it about 1/16" thicker than the other. On top of it, the piece is slightly curved. When it lies on a flat surface, the center shows a 1/16" hollow.
My question is, can I get it level with my router so it's perfectly flat? The final thickness is not critical, I can go down to 3/4". It may sound trivial to you guys but as a router newbie I don't know where to start.
Ed
router king is offline
post #2 of 25 (permalink) Old 06-19-2016, 02:52 PM
Ed.. if I guess right you want to flatten this piece and make the thickness uniform all the while removing a cup in the wood...
if so, you want a ski or on of Gaffboat's (aka Oliver) adaptable nifty guides...
let us know and we can carry on...
I believe a wide planer/straight/mortising bit is in your future...
what you'll end up doing...
TWheels and TwoSkies57 like this.
Stick486 is offline
post #3 of 25 (permalink) Old 06-19-2016, 03:52 PM Thread Starter
First Name: Ed
Wow,
That was a quick response. Those images makes a lot of sense to me, although I do not know what "ski or on of Gaffboat's (aka )liver) adaptable nifty guides" means.
How is the board you are working on fixed to the bottom part of the jig?
post #4 of 25 (permalink) Old 06-19-2016, 04:14 PM
Originally Posted by router king View Post
Wow,
That was a quick response. Those images makes a lot of sense to me, although I do not know what "ski or on of Gaffboat's (aka Oliver) adaptable nifty guides" means.
quick response...
musta been an accident...
a router ski...
for all intent and purpose the guy doing the routering is using a ski...
there are quite a few variations of them...
do a search here and you'll see what I mean...
Gaffboat's...........
the three bottom renderings are Oliver's design and if you study them they can be adapted to your mission...
hence Gaffboat's (aka Oliver) adaptable nifty guides" means.
the board that is being worked on is double stick taped or clamped down firmly and the router is moved about the surface of the board... that's not me BTW...
so can you answer the questions I had for you???
Stick486 is offline
post #5 of 25 (permalink) Old 06-19-2016, 04:20 PM
Visualize the red perpendicular boards that are to the top extending down to the table/bench and the jig carrying the router clear of your work piece...
Stick486 is offline
post #6 of 25 (permalink) Old 06-19-2016, 04:24 PM
Further to Stick's comments; if the Board's not lying flat on the work surface, ie it's rocking a bit, you might need to tuck shims under the two opposing corners that are causing the rocking.
The consequence of doing that is of course, once you've flattened the top side, you'll need to flip it over and redo the bottom...now the two faces will be parallel and of even thickness everywhere.
TwoSkies57 and Stick486 like this.
DaninVan is online now
post #7 of 25 (permalink) Old 06-19-2016, 04:30 PM
Gaffboat... (Oliver)
Router Forums - View Profile: Gaffboat
Coincidentally he's here, viewing a different thread!
post #8 of 25 (permalink) Old 06-19-2016, 04:33 PM
guess his ears aren't ringing yet....
make that burning...
@Gaffboat ...
Stick486 is offline
post #9 of 25 (permalink) Old 06-19-2016, 04:48 PM
Gaffboat's Avatar
First Name: Oliver
Jeez! A guy can't have any privacy. So much for worrying about NSA spying, now I have to worry about the forum. Hmmm. Maybe I should wear a disguise while browsing. Let's see, dark welding goggles? Check. Shop apron on backwards? Check. Knit cap pulled down towards eyebrows? Check. Noise muffs in place? Check. Okay this disguise will work. Hey wait, I can't see anything and I've gone deaf.
DaninVan and Stick486 like this.
Gaffboat is offline
post #10 of 25 (permalink) Old 06-19-2016, 04:56 PM
schnewj's Avatar
Not only that, but you now look like Stumpy Nubs! So, cut it out.
DaninVan likes this.
schnewj is offline
Routing box joints advice required. JJC General Routing 13 11-11-2013 02:59 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
Making mantel clock--need advice on routing groove into frame for glass insert IronHorseDriver Starting Off 5 02-19-2013 02:41 PM
Seeking advice on Router Table AmitChattoraj Table-mounted Routing 6 01-21-2013 05:24 PM
New to the forum and to routing, looking for advice cash2003 General Routing 11 03-24-2011 05:35 AM
