painting foam - Router Forums
post #1 of 2 (permalink) Old 06-30-2016, 08:49 AM Thread Starter
Default painting foam
I cut a sign out of 25 psi high density foam and would like to get idea for exterior finish that will hold up and maybe finish that will make it hard so not to dent.
shortys is offline
post #2 of 2 (permalink) Old 06-30-2016, 10:16 AM
What we've found out when using Corafoam (don't know how that compares to your stuff) is to use ALL 100% acryllic paint. Don't even have to put a finsh clear coat of any kind on it then. There are Corafoam sign carvers up here doing that and guaranteeing their work for 10 years. And these are the "pros" doing the big custom carved business signs.
Otherwise, you have to use either spar varnish or spar urathane with UV protection as a clear coat and recoat it every 2-3 years.
HJ
honesttjohn is online now
DIY Foam Padded Case MT Stringer Show N' Tell 17 03-16-2016 05:34 PM
Polyurethane glues- the foam is not for filling gaps Cherryville Chuck Tool Reviews 13 02-28-2015 11:24 PM
Foam Shadow boxes afpchrisd General Routing 5 09-26-2014 07:28 AM
Routing rigid foam? bobbotron General Routing 12 01-17-2013 06:56 PM
Turning foam on a lathe? Bulldogg629 Woodturning and Lathes 9 07-01-2012 02:16 AM
