Help finding bit - Router Forums
post #1 of 11 (permalink) Old 07-22-2016, 11:35 AM Thread Starter
Default Help finding bit
Hi,
I am a complete amateur so do not know what to call this edging treatment so do not know what bit I need or under what name to search for it. Need to more or less match shelf edging on an old
cupboard I'm fixing up.
Thank you,
Alan Smith
Alansmith is offline
post #2 of 11 (permalink) Old 07-22-2016, 11:54 AM
the bit you are looking for is called a beading bit...
post #3 of 11 (permalink) Old 07-22-2016, 12:29 PM
https://www.amazon.com/Freud-80-122-.../dp/B00004T7K9
They come in different sizes depending on what you want the radius of the rounded part to be. The link shows a bit that will make a narrow flat bottomed groove but they are available that will will make a pointed groove too.
post #4 of 11 (permalink) Old 07-22-2016, 01:40 PM
vindaloo's Avatar
First Name: Angie
To get the sharp V groove you'll need a point roundover bit for the dips and a roundover bit for the edges.
Point Roundover
Roundover
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #5 of 11 (permalink) Old 07-22-2016, 02:14 PM
Hey, Alan; welcome!
DaninVan is online now
post #6 of 11 (permalink) Old 07-23-2016, 10:52 AM Thread Starter
Thanks to everyone for the help. I thought it was a beading bot but the ones I looked at were not right.
Then I thought it might be a reeding bit but.....
I'm on it.
post #7 of 11 (permalink) Old 07-23-2016, 12:21 PM
bcfunburst's Avatar
First Name: Reg
Welcome to the Forum, Alan. There are a few different sizes of Beading Bits. This is your excuse to do some shopping!! Enjoy!!
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #8 of 11 (permalink) Old 07-23-2016, 03:12 PM
gjackson52's Avatar
First Name: Gary
Welcome to the forum !
Gary
gjackson52 is offline
post #9 of 11 (permalink) Old 07-23-2016, 07:26 PM
TWheels's Avatar
It seems each seller has a different specific name for the bit, the bit shown by the links given by Angie is called a Beading bit by Lee Valley, a Full Bead by Infinity, a Leaf Edge Beading by Amana, Point Cutting Roundover by Whiteside and MLCS, etc. These bits all would require two cuts on each corner to get the profile you want.
Amana has two bits that might do it in one cut. They call one a Drawing Line bit, and another an Edge Beading bit.
If you choose to go wth Amana please heed the advice of @Stick486 to be sure it is made in Israel and not China.
(Please note that by one cut I mean possibly multiple passes without changing the height of the workpiece relative to the bit.)
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #10 of 11 (permalink) Old 07-24-2016, 05:14 PM
CharleyL's Avatar
First Name: Charley
Point Roundover
Roundover
No, a beading bit in a router table with the piece standing on edge just like shown will round over the bottom corner and put the rounded groove in. Then the piece will need to be inverted and run past the bit again to do the other groove and edge.
Here is a sample picture of a beading bit, but there are several slightly different
versions. Do a search to find the exact profile that you want.
Corner Beading Router Bits - Toolstoday.com - Industrial Quality Carbide Tipped Router Bits
You would use this one set to produce the shape on the lower picture to the right of the bit image, but with the bit and image upside down since the bit should be in a router table for this operation.
Charley
Central North Carolina
CharleyL is offline
Help Finding a 1/16" Router Bit jgrey Router Bits - Types and Usage 15 07-18-2013 03:25 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
Router Bit Accuracy Mike Wingate Router Bits - Types and Usage 8 06-24-2009 12:38 PM
help in finding router bit woodhead Router Bits - Types and Usage 1 03-14-2006 02:16 PM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 09:20 PM
