Dremel Plunge Router Uses - Router Forums
post #1 of 13 (permalink) Old 07-25-2016, 09:39 AM Thread Starter
First Name: Gary
Default Dremel Plunge Router Uses
I received a Dremel Plunge Router as a christmas gift, and I just received a set of (10) router bits I ordered from banggood.com. I was wondering if anyone has a dremel plunge router, and what do you use it for?
gmercer_48083 is offline
post #2 of 13 (permalink) Old 07-25-2016, 09:50 AM
Gene Howe's Avatar
First Name: Gene
I use mine just like a full sized router, only on a much smaller scale.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 13 (permalink) Old 07-25-2016, 09:55 AM Thread Starter
First Name: Gary
What does it excel at?
post #4 of 13 (permalink) Old 07-25-2016, 10:17 AM
First Name: Andy
I like mine for small freehand jobs. Like morticing for hinges or small cabinet locks where the job is too small to be worth making a jig for. Or routing out for an inlay piece. The clear base and easy controllability make it good for freehand work.
It's also good for putting a chamfer or round-over on edges where a convetional bearing-guided bit won't fit. The Dremel edging bits are guided by a pin that's much smaller. An example is I routed out recesses on a chest for flight case handles. The recesses needed rounded over edges, but were too shallow to do it with a bearing-guided bit.
One thing I have found it's no good for is making straight cuts against a straightedge or using the edge guide. The base is all-plastic and too flexible. The torque of the cutter is enough to flex it, so your cut moves around as you start and stop moving.
The other main limitation is that setting the cut depth is very hard to do accurately. Trial and error on a test piece seems to be the way to go.
AndyL is offline
post #5 of 13 (permalink) Old 07-25-2016, 10:27 AM
hawkeye10's Avatar
First Name: Don
It excels in very light duty work when you need a router that is light in weight. They can be very handy at times.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 13 (permalink) Old 07-25-2016, 10:29 AM
Gene Howe's Avatar
First Name: Gene
With the V groove bits, and with a little practice, following a penciled design is fairly easy.
Add the edge guide for straight grooves.
The profiled bits do a great job for decorative edging.
I just looked and the set from Bangood doesn't include the straight V Groove bit. My closest Ace store has a good selection. Or an online search will yield quit a few bits to round out your bit supply. Be aware that these bits are not carbide and dull fairly fast. It's nice to have a couple often used bits in reserve.
Gene Howe
Snowflake, AZ
post #7 of 13 (permalink) Old 07-26-2016, 07:21 AM Thread Starter
First Name: Gary
I was surprised to find the dremel plunge router base is a bosch product. Seems to be high quality, but router bit selection found in stores is kinda pathetic...had to order online to get a selection. I could only find high speed bits in a variety (hope thy hold up).
post #8 of 13 (permalink) Old 07-26-2016, 09:22 AM
Gene Howe's Avatar
First Name: Gene
Lowe's has a carbide engraving tool set of 11 bits.
Shop Dremel 11-Count Tungsten Carbide Engraving Bits at Lowes.com
Gene Howe
Snowflake, AZ
post #9 of 13 (permalink) Old 07-26-2016, 10:57 AM
tvman44's Avatar
First Name: Bob
I bought the plunge accessory for my Dremel but have yet to use it.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #10 of 13 (permalink) Old 07-26-2016, 11:08 AM
N'awlins77's Avatar
First Name: Lee
Yea I have it too, and never used it yet. The plunge base, not the Dremel. The Dremel, I use a lot!!
N'awlins77 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 07:02 PM
trimmer router vs dremel with plunge base paduke Portable Routing 6 12-22-2014 10:49 AM
Question about plunge base on Ridgid router Sawatzky General Routing 12 01-01-2011 11:44 PM
