how to route a groove. - Router Forums
 15Likes
post #1 of 33 (permalink) Old 07-25-2016, 04:48 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default how to route a groove.
I want to route a V groove 1/2" from the edge around this oval. I want to do it the safest [as in no goofs] way. This is my third time to make this sign and I am tired of it. On one of my mess up's I used double stick tape to attach a block of wood to the routers base and use that as a fence. I could do it but it's risky. The other way is use the router table and drop the sign on top of the bit and let the sign ride the fence. So far this seems the best way. I am just looking for more and better ideas.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 33 (permalink) Old 07-25-2016, 05:01 PM
First Name: Richard
My choice would be the router table.
Shop guy is offline
post #3 of 33 (permalink) Old 07-25-2016, 05:05 PM
Gene Howe's Avatar
First Name: Gene
Make a V shaped guide for the table router large enough to accept your sign. 2X2s would be good. You'll likely need to cut the ends of the legs to set against the fence at the angle you'll need for the V to fit your circle. Center the bit between the legs of the V, and far enough away from the fence to give you the half inch you want.
Then hold the sign in place against the guide and lower it onto the spinning bit and turn it against the rotation of the bit.
Hope that made sense.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #4 of 33 (permalink) Old 07-25-2016, 05:06 PM
pencil in the line..
hand router it w/ inlay groover...
make a smaller oval template ans use a bearing guided bit or your bushings in your router...
post #5 of 33 (permalink) Old 07-25-2016, 05:17 PM
The issue with doing it with an edge guide or like Gene suggests is that the shape is elliptical and will bridge across the gaps differently where the slope has a larger radius that it will on the ends where the radius is smaller. The most accurate method I would say is to cut the shape out of some scrap and use that as a template and then use a guide bushing.
post #6 of 33 (permalink) Old 07-25-2016, 06:31 PM
Gene Howe's Avatar
First Name: Gene
Looks round to me. Chuck is right. If it's elliptical, my method won't work.
Gene Howe
Snowflake, AZ
post #7 of 33 (permalink) Old 07-25-2016, 08:39 PM
it's elliptical....
post #8 of 33 (permalink) Old 07-25-2016, 09:02 PM
I think Stick's got it right.
HJ
honesttjohn is offline
post #9 of 33 (permalink) Old 07-26-2016, 01:50 AM
paduke's Avatar
In doing my platter I learned concentric ellipsis are difficult to layout. I used the string method to do one Then wanted one 1/2" smaller so I moved the pins 1/2" Nope its not concentric trace the shape to make a jig to hold it or freehand a hand drawn inner line which is something I can not do Bill free hand =booboo
paduke is offline
post #10 of 33 (permalink) Old 07-26-2016, 04:04 AM
TWheels's Avatar
Don, what are the dimensions (major and minor axes) of your (beautiful as it is) sign? What is the width of the V-groove you want to cut?
Rockler sells an ellipse jig http://http://www.rockler.com/rockle...cle-router-jig
Another possibility using sacrificial pieces and template guides: (it is now 4 AM and I need to get some sleep.I thought I had the template guide siizes and router bit sizes figured out but it required a template guide size only available from Oak-Park. Can the 1/2 inch centering of the V-groove be off by 1/16 inch? To be continued.)To be continued.)
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
How to route a 1/4" x 1/4" groove in this base. adot45 Guide Bushings and Templates 15 12-04-2015 05:33 AM
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
O-ring Groove on a Cylinder jck General Routing 4 12-14-2011 03:56 PM
How to Route an "O" Ring Groove lemonyx Starting Off 7 08-02-2009 04:59 AM
Wedge tonuge and groove (CMT 855.510.11) Drew Eckhardt Router Bits - Types and Usage 2 01-23-2009 09:39 PM
