Need some help restoring a vintage Craftsman router (315.25050) - Router Forums
 8Likes
post #1 of 12 (permalink) Old 07-28-2016, 08:52 PM Thread Starter
Default Need some help restoring a vintage Craftsman router (315.25050)
So I recently bought a 315.25050 router in pretty beat up shape in the hopes that I could fix it up. There are a few things missing that need replacing. Specifically, the motor brushes, the brush caps, and the collet/nut. If any of you have this particular router and could take pictures of these items or measure them for me, that'd help a lot.
The 315.25031 seems to be more common and is pretty similar, so the brushes and caps are likely to be the same. I'm not sure if the collet/nut would be as the biggest difference that I can tell is that the spindle is threaded on the 25031 and is not on the 25050. Instead I have this piece that screws on to the end of a "star-shaped" spindle. So I'm looking for some kind of replacement. It is 5/8" with a fine thread (is that typical?) and its interior diameter is 7/16" and then about 3/16" inches in the diameter shrinks down to 11/32". (I'll post a picture so that makes more sense.)
I'd appreciate any info/help!
nonegoodleft is offline
post #2 of 12 (permalink) Old 07-28-2016, 09:02 PM
welcome to forums oh nameless one...
IIRC sears 315.xxxx routers were made by Ryobie... knowing this may be of some help...
be aware that parts for older (even by 5~6 years) sears tools are harder to come by than hen's teeth...
Ray Newman likes this.
Stick486 is offline
post #3 of 12 (permalink) Old 07-28-2016, 09:21 PM
Hey, Nonegoodleft; welcome!
Does it have some sentimental value? Technology has left that machine to History.
Modern routers are a joy to use and have become very affordable, at least in the US.
Just my opinion (this coming from the guy that has to crab walk into his shop) but it's not a great investment of either time or money.
Now if it was one of the old Stanleys from the '60s, well then we'd be talkin'!
DaninVan is online now
post #4 of 12 (permalink) Old 07-28-2016, 11:47 PM
Check out a factory refurbishes Bosch 1617. Not expensive and a joy to use. May find a new kit on sale somewhere for about $200. Less frustrating and you won't need to track down parts.
DaninVan and hawkeye10 like this.
post #5 of 12 (permalink) Old 07-29-2016, 12:11 AM
Welcome None. If Sears shows that those parts are unavailable then I can pretty much guarantee you that they can't be had new. You might be able to find a used one for parts on ebay or Craig's List but also a long shot. As suggested they really aren't worth putting much money into. One of the problems is that Sears contracts with the manufacturer to buy a certain number of units and when they are ready to buy more the model has changed. If you look in our manuals section for Sears routers you'll see a lot of 315 (Ryobi) router models are in there and that is not all of them.
Ray Newman and DaninVan like this.
post #6 of 12 (permalink) Old 07-29-2016, 05:45 AM
hawkeye10's Avatar
First Name: Don
Here is a link to the refurbished routers Tom was talking about. I have bought several from this company and have been very happy.
Reconditioned Routers and Trimmers
DesertRatTom likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 12 (permalink) Old 07-29-2016, 05:47 AM
they have done right by me also...
Stick486 is offline
post #8 of 12 (permalink) Old 07-29-2016, 10:26 PM Thread Starter
Thanks for all the comments so far, everyone. I got the router for <$20 so I'm hoping I can fix it up and use it for less than $200. Also, fixing it up is half the fun! So does anyone have a collet/nut that would fit what I have? Is 5/8" a common size of collet nut?
post #9 of 12 (permalink) Old 07-29-2016, 10:29 PM
tags, tax, and title...
Factory Reconditioned Bosch 1617EVSPK-RT 12 Amp 2.25 HP Combination Plunge and Fixed-Base Router Kit
Factory Reconditioned Bosch 1617EVS-46 2.25 HP Fixed-Base Electronic Router
Stick486 is offline
post #10 of 12 (permalink) Old 07-30-2016, 12:18 AM
None there are a lot of variations in collets because the slope of taper in the cone has to match the slope on the collet as well as diameter and there doesn't seem to be any standard for that. Some of the Sears/Ryobi models were quite different with the end of the armature shaft being the collet and the nut squeezing the shaft tight against the bit shank. I have one of those which my father in law left me and it isn't holding bits tight which means to fix it means replacing the armature (pure genius right?). I'm now trying to figure out what I can do with a perfectly functioning motor that won't hold a bit. I'm not familiar with what you showed but you could really be fighting an uphill battle to repair something that really isn't considered vintage.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
integrating INCRA jig parts with Craftsman TableSaw & Router: Part 1 SimonHartropp Jigs and Fixtures 2 09-10-2015 07:15 PM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
