victor - Router Forums
post #1 of 12 (permalink) Old 08-18-2016, 11:16 AM Thread Starter
Send a message via Skype™ to Victor Lujan
Default victor
I make signs freehand and with templates with fixed base,bought a new router craftsman #320-27683 comb fixed and plunge,cant figure out how to set for multi depths using the depth rod want to start at 1/8''then finish with 5/16ths using the turret
Victor Lujan is offline
post #2 of 12 (permalink) Old 08-18-2016, 11:59 AM
hawkeye10's Avatar
First Name: Don
Victor here is the owners manual for that router maybe this will help find your answer. I hope so.
CRAFTSMAN 320.27683 OPERATOR'S MANUAL Pdf Download.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 12 (permalink) Old 08-18-2016, 12:10 PM
Hi Victor and welcome. One easy way to do it is to take a 5/16" drill bit or keystock (anything that is 5/16" thick) to measure it. Lock the router with the bit level with the base and just touching the work surface it's on. Turn the turret to its lowest position under the depth stop rod. Place the 5/16" gauge between the depth rod and the turret and lower the rod and lock it in place. That will give you the final cut. If you have fine adjustment screws in each step of the turret then without moving the rod turn the turret and adjust the screw until a gauge of appropriate size fits between the depth rod and the turret screw. If you don't have fine adjustment screws then you are stuck with what the turret gives you or you can go through the same procedure as the initial setup for each step.
post #4 of 12 (permalink) Old 08-18-2016, 12:41 PM Thread Starter
been there no help thanz
post #5 of 12 (permalink) Old 08-18-2016, 12:55 PM Thread Starter
there is no adjustment screws on the turret only a rod for the adjustments on the router and there adjustments are 1/4'' to 3/4'' so the way it is set up for this router only 3 adjustment per cut if you use this turret so have to adjust each time for diff. cuts tried to take it back went pass the 30 days called dealer they said u can return it for the same thing thanz 4 help
post #6 of 12 (permalink) Old 08-18-2016, 01:16 PM
hawkeye10's Avatar
First Name: Don
Victor there are a lot of unknowns here. In a lot of wood cutting a 5/16th in one pass is very doable. Wood such as pine, western cedar and others. Very hard wood might take two cuts at the most. Also a lot depends on what router bit you are using and the size and quality of the bit. A 1/8th bit is very fragile while a 1/2" bit will be stronger. Maybe some pictures would also be helpful. The more information we have the better answers you will get.
post #7 of 12 (permalink) Old 08-18-2016, 07:22 PM
old55's Avatar
First Name: Ross
Welcome to the forum Victor.
Ross,
old55 is online now
post #8 of 12 (permalink) Old 08-18-2016, 07:52 PM
Welcome to the forum Victor....
post #9 of 12 (permalink) Old 08-19-2016, 10:20 AM
stanzee's Avatar
First Name: Stan
Default ingthe turrets
page 23 of the manual provides instructions for setting more than one depth of cut using the turret system. Setting the final depth is done on the lowest turret position and up to two lesser depth cuts on the other two positions.
If you are having getting the drift of the procedure I suggest a search on you tube where you will probably find several illustrations. I am sorry I don't have time right now to search for a link.
Good luck.
stanzee is offline
post #10 of 12 (permalink) Old 08-19-2016, 11:37 AM Thread Starter
well I figure out my problem,I remove my turret from my router and machined and tap out new threads on turret ,now I'm going to sell my idea to craftsman for a BUTt LOAD OF $
Introduction Roughedges New Member Introductions 3 03-19-2013 12:49 PM
Chinese Production istracpsboss Lobby 53 01-18-2010 04:27 PM
