Textures in sketchup - Router Forums
 6Likes
post #1 of 16 (permalink) Old 08-09-2015, 10:29 AM Thread Starter
PhilBa's Avatar
First Name: phil
Default Textures in sketchup
As I have said before, I like to use textures in sketchup. They are great for getting an idea of how your actual wood choices will look. It's not exact but does help a lot. Helps a lot when showing the idea to others to get their input.
You can import any 2D image to use as a texture. You can find lots of wood textures in the internet. The bigger the better. If it's too small, it will get repeated. So some tricks I use to get the most out of textures:
- Use google image search. I search for the wood type plus the word texture. In size, select large. There are a lot of nice images that will work out there.
- I download my textures into a separate directory (textures, duh...)
- To import to a model, I select file/import and click on "use as texture". You can only drop the texture onto a simple surface (no components or groups) so I usually draw a rectangle. Once it's imported, the texture will be available in the "in model" section of the materials window.
- When importing, I try to size the texture so the grain is about the right size. I usually draw a 12" X 12" square and make sure the grain is appropriately sized. Personal taste.
- With most texture images you find on the internet, there is some color or intensity variation across it. So, when the texture repeats on larger surfaces, you can distinctly see the edges. They're called tiling artifacts. To prevent that I create a "book matched" texture. Basically, I repeat the image 3 more times. The top left one is the original, the top right is mirrored horizontally so that the right edge pixels are exactly the same as the left edge ones. Then I copy those two images and flip them vertically so that the bottom row of pixels is the same at the top row. That "quad image" becomes the new texture image.
The end result is that you don't see the tiling artifacts. See the examples below. The first picture is the original image and the second shows the difference between the orignal (left) and "quad image" (right) used as a texture. I think you'll agree it looks a lot more natural. You can play around with selecting different parts of the image to base the new quad image on so the grain looks even better. I probably should have clipped out some of the right hand side of the image to make it even more natural.
I use MS Paint for this, it's a bit tedious. I've got in mind to write a simple program to do this automatically. Would be nice to just have a check box in the import function in SU.
Name:	oak white american-1.jpg
Name:	oak texture test.png
PhilBa is offline
post #2 of 16 (permalink) Old 08-09-2015, 10:44 AM
MT Stringer's Avatar
Thanks Phil. Time to fire up the google machine.
MT Stringer is offline
post #3 of 16 (permalink) Old 08-10-2015, 10:46 AM Thread Starter
PhilBa's Avatar
First Name: phil
More tricks for textures.
- I often make 2 versions of a texture - horizontal and vertical. One is rotated 90 degrees to the other. This lets you easily get the grain running the right way on your components.
- You can "paint" a texture on a surface but it's easier to paint the component. Different copies of a component can have different materials (textures) and still be the same component.
- The cutlist plugin looks at the component material name (i.e. texture) when matching to the sheet material names. I have a texture called "baltic birch" and use that on anything intended for plywood.
Gaffboat likes this.
PhilBa is offline
post #4 of 16 (permalink) Old 08-10-2015, 01:29 PM
Guest
Does anyone know of a good alternative to Sketchup that will run on Win XP SP3?
163481 is offline
post #5 of 16 (permalink) Old 08-30-2016, 06:42 AM
Upgrade that computer!!! :-)
grantcarmichael is offline
post #6 of 16 (permalink) Old 08-30-2016, 06:45 AM
Great post! I'll try to dink around with some textures!
post #7 of 16 (permalink) Old 08-30-2016, 07:03 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Ignore the man!. XP has been good for me. had this laptop just over 8 years now, does everything I need it to.
I even got a sketchup on it a while back but I'm too impatient to learn it so removed it again.
sunnybob is offline
post #8 of 16 (permalink) Old 08-30-2016, 07:11 AM
don't believe it..
post #9 of 16 (permalink) Old 08-30-2016, 07:14 AM
Sketchup 5 and Windows XP Pro 64 bit OS - Google Groups
google sketchup free download for Windows XP - Softonic
Download SketchUp | SketchUp
Downloading older versions | SketchUp Knowledge Base
Rogerdodge likes this.
post #10 of 16 (permalink) Old 08-30-2016, 09:58 AM
Having horizontal and vertical textures would be a BIG time saver. Now I have to understand everything you wrote. Maybe you would consider creating a repository of your textures.
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
Sketchup plan distribution PhilBa Google Sketchup 1 08-08-2015 02:54 PM
Sketchup Help - Tablesaw Outfeed (T-Track) Table nsecrist General Routing 18 03-26-2015 07:41 AM
Sketchup textures Gaffboat Project Plans and How To 4 11-26-2012 06:18 PM
Sketchup and Woodworking BigJimAK Lobby 21 10-24-2009 11:46 AM
Grrrrr Sketchup 6 & 7 allthunbs Tools and Woodworking 3 01-21-2009 08:12 PM
