Mounting plate for Hitachi KM12VC router - Router Forums
 2Likes
  • 1 Post By cavalier19
  • 1 Post By Nickp
post #1 of 9 (permalink) Old 09-23-2016, 02:20 AM Thread Starter
Country: India
Default Mounting plate for Hitachi KM12VC router
I am a newbie just starting off. I need advice on which mounting plate to buy for a Hitachi KM12VC router. The prices vary a lot on the net, from $13 for a Grizzly plate to around $ 40 for most other plates.. Can anyone guide me.
cavalier19 is offline
post #2 of 9 (permalink) Old 09-23-2016, 10:56 AM
Hi Cavalier. Some plates are predrilled for a few routers but I know that none were drilled for my two large Hitachis, a M12V and M12V2 which aren't the same frm one to the other either. You will probably have to drill your own and there are instructions on our homepage on one of the subforums. I don't hold my plates in my tables with any fastener, they just sit there and that allows me to pull them out when changing bits, making major adjustments, or when I'm not using them. I use the Grizzly plate but I don't recommend that you leave it in he table when not using it. You can get aluminum plates that are very pricey and then you shouldn't need to worry about that.
post #3 of 9 (permalink) Old 09-23-2016, 12:05 PM
I get the Grizzly T10432047 plates a half dozen at a time. I have never had any of them sag but I did get one that came defective out of a couple dozen.
post #4 of 9 (permalink) Old 09-23-2016, 12:21 PM
I recently popped for the expensive Woodpecker plate for my Triton. I had to drill the hole for the lift crank, but that was pretty easy (use a rat tail file to smooth the edges). I got it because of the twist lock insert. Many plates require unscrewing the insert--don't lose those screws! The twist lock makes changing bits fast and easy . I use Sommerfeld matched bit sets so I don't have to reset the bit height. The Woodpecker is a bit thicker and larger than the Rockler plate it replaced, so I got the Woodpecker template as well. I think there are a couple of other brands with the twist lock (bayonet) insert, but for me the extra cost of the Woodpecker plate was worth it. Mark and drill the holes carefully. With aluminum plates, drilling is 't much of a chore, but do use a drill press if you can, and countersink the holes to get the mounting screws below the surface.
post #5 of 9 (permalink) Old 09-26-2016, 12:19 AM Thread Starter
Country: India
Hi, Tried to source the Grizzly plate but failed. Can anyone guide me as to where I can get some. I have decided to go ahead with drilling my own plate. Thanks for the valuable inputs. Much obliged
jj777746 likes this.
post #6 of 9 (permalink) Old 09-26-2016, 06:23 AM
boogalee's Avatar
First Name: Al
PT10432047 INSERT W/GUIDE PIN 9 X 12
Grizzly Outside the U.S. (360) 647-0801
Al B
boogalee is offline
post #7 of 9 (permalink) Old 09-26-2016, 03:04 PM
Nickp's Avatar
First Name: Nick
...6 at a time...? You're not making lasagna with them, are you...? Way too al dente...
Mike likes this.
Nick
Nickp is online now
post #8 of 9 (permalink) Old 09-26-2016, 07:07 PM
Nick, this is one of the items I keep on hand to assist new friends; I have a couple extra sets of brass set up bars too. I have mounted quite a few routers over the years for myself and others using the methods shown here: http://www.routerforums.com/table-mo...tml#post127219
And here: http://www.routerforums.com/table-mo...tml#post122017
Name:	Plate mount 003.JPG
Name:	Plate mount 004.JPG
post #9 of 9 (permalink) Old 09-27-2016, 03:27 AM Thread Starter
Country: India
Thanks for the tips.
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
Mounting plate for router in table? tdale Table-mounted Routing 2 02-26-2012 12:58 PM
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
