Reverse template - Router Forums
 1Likes
  • 1 Post By scottgrove
post #1 of 4 (permalink) Old 10-11-2016, 01:46 PM Thread Starter
Default Reverse template
I was looking at a picture of a natural edge table with a wavy piece of glass running down the center of the two pieces and am woundering how you come to get a glass piece that fit so well. I can't figure the seaquence that you would do to route a template for the glass. Any help thanks.
Wirenut26 is offline
post #2 of 4 (permalink) Old 10-11-2016, 05:17 PM
Honored Member
First Name: pat
Not a particular problem making a matching template(s).
Does take some experience and a reasonably smooth edge, however.
Convoluted templates, down to the radius of the cutter, are possible.
And if done with laser, can be tighter than a router bit radius.
Quillman is offline
post #3 of 4 (permalink) Old 10-11-2016, 09:43 PM
Welcome to the forum Bill. As Quillman hinted at it`s a matter of using different guide bushings to match up different offsets.
post #4 of 4 (permalink) Old 10-12-2016, 08:49 AM
First Name: Scott
Use a 1/2" router bit with a 1" od template guide and use the glass as a template cutting another template out of MDF. (You will be running your guide on the inside and cutting the template on the outside of the cutter, so hold the template guide tight to the glass)
Then use a 2-1/2" template guide (make one) and using the MDF template cut the slab.
This system of off set template guides basically move the router bit to either side of the seam and will align any complex curve perfectly.
Enjoy!
Wirenut26 likes this.
scottgrove is offline
Can't get the hang of template routing kglade Starting Off 39 04-07-2016 11:00 AM
Advice on Cable Grommet Techniques plunger Starting Off 13 10-03-2015 02:03 AM
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
How to Make a router Template MT Stringer Jigs and Fixtures 8 04-22-2015 02:46 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 04:44 PM
